Vw radio, multimedia, navigacija, bluetooth,
Novo
Radio za Golf 5, Golf 6, Eos, Caddy, Touran, Sharan...škoda vozila, octavia, roomster...
Može se postaviti VW i škoda znak
Radio ima navigaciju, radio sa RDS, bluetooth, video u vožnji, stanje rezervoara u litrama i sl...prikaz klimatronika, parkirnih senzora...i jos puno toga...utor za USB i microSD karticu
Na pm ili 099/3000-313
2300 kn
New Technology + All in One + Competitive Price + High qualityOriginal Design with standard VW UI/Connector/Apperance, ISO and VW 2 Harness for old and new VW Car, Standard Radio Antenna Port + Multi Function Socket + Cooling Board, Built-in Dual Channel CanBus Decoder, just Plug to Play
MTK3360 800MHz CPU, Dual Core, 256MB RAM, support OPS/Radar/Air Climate Control/OBD/Backing Track Display, support 1080P RMVB Video, support the newest 10-Band EQ, VMCD---Virtual Multi CD Changer, Bluetooth BT-Music and PB-Download, Steering Wheel Control, GPS and 4GB Card with Maps
KEY FEATURES:
- This unit will fit the following car model:
VW PASSAT CC (2008 to 2013), PASSAT (2005 to 2013), Golf 5 (09/2003 to 2013), Golf 6 (08/2008 to 2013),
Tiguan (2007 to 2013), Touran (2003 to 2013), EOS (2006 to 2013), Jetta (2005 to 2013),
Caddy (2003 to 2013), Sharan (2010 to 2013), Amarok (2010 to 2013), Scirocco (2008 to 2013),
Polo V 6R (2009 to 2013), Multivan T5 (2010 to 2013), New Bettle 2 (2011 to 2013).
SEATAltea (From 05/2004), Leon (From 09/2005), Toledo (From 12/2004), Altea XL (From 04/2007)
Note: This unit has front panel size 220mm(Top width)*130mm(High)*210mm(Bottom width),
please check your dashboard size before bid to avoid mistake!
- Original Design with standard VW UI/Connector/Apperance, ISO and VW 2 Harness for old and new VW Car
- Standard Radio Antenna Port + Multi Function Socket + Cooling Board
- Built-in dual channel CanBusDecoder incl. support Car OPS/Radarand A/C ControlDislpay,
- Support the OBDDisplay and Backing TrackDisplay
- 7" Digital Screen(800*RGB*480), High sensitive Touch Screen
- The newest MTK3360 800MHzCPU, Dual Core, 256MBRAM, support external memory up to 32GB
- 4 x 50wSurround Stereo, SubwooferOutput, support the newest 10-Band EQ
- Multi Menu Languages:English/Chinese/Russian/French/German/Italian/Spanish/Portuguese/Arabic...
- Fluorescent Button with red light for use in the night
- One button for blank screen, you can shut off Display but keep Sound in the evening
- Built-in Clock and Calendar,Clock/Date/Week/Time Zone adjustable
- Support Virtual Multi CD Changer, you can save max. 12 CD in your SD Card to play
- Support GPSnavigation, free 4GB SD Card with maps and GPS Antenna included.
- Dual zonefunction, Rear Passengers can watch DVD or TV while driver can use GPS
- Support Bluetooth hands-freefunction, built-in microphone on front panel.
- Support A2DP Bluetooth, can play stereo music through Bluetooth from your Phone
- Download phone bookfunction, you can download contact information from your phoneto this unit
- FM/AM RadioTuner, 30 Preset Radio Stations (FM: 3*6, AM: 2*6)
- USBPort and SDSlot, Support USB Stick and SD Card up to 16 GB, support 1080P RMVB Videos
- Support iPod/iPhone Charge + Audio Input + Touch Control
- Support Rear View Camerainput and reverse trigger Control
- Support Steering Wheel Control,Hand Brake Control
- Electronic Anti-Shock, Last Position Memory
General
-Power Supply: DC 12V (allowable range: 10.8-14.5)
-Max Current: 10A
-Button Backlight Color: Red
-Install Size: 2 din size 170mm*140mm*100mm
-Package Size: 290mm*250mm*210mm
-Gross Weight: 3.5kg
-Net Weight: 3.0kg
Display
-Screen Type: 7 Inch Touch Screen
-Resolution: 800 * RGB * 480
-Built-in Clock and Calendar : Yes
-Theme : 5
-Change the Backlight: yes, you can choose Day/Night and adjustable
-One Button for Blank Screen: Yes, Shut off Display but keep Sound in evening
-Digital or Analog : Digital Touch Screen, very vivid
Setup
-Audio setup: User/pop/Rock/Jazz/Class
-EQ Setup: Support the latest 10-band EQ
-Navi Path setup: Yes
-Theme setup: Yes, 5 theme to choose
-Bluetooth Setup:Yes
-Menu Multi-languages: English/Chinese/Russian/Turkish/French/German/Italian/Spanish/Portuguese/Hebrew/Arabic
-Radio Setup: Yes, choose radio system
-Video Setup: Yes, Bright/contrast/backlight
-Reverse Setup: Yes
-Sound Setup: User/Flat/Pop/Rock/Jazz/Class
-Date/Time Setup: Clock/Date/Week/Time Zone adjustable or GPS Time
GPS
-Operation System: Microsoft Windows CE. NET 6.0
-CPU: MTK3360 800mHz,
-Internal: 256MB
-External Memory Size: can extended to 32GB
-Supported Map: SYGIC, IGO,Garmin and so on
-Free 4GB TF Card included: yes
-GPS Menu Operation Languages: English/Chinese/German/French/Spanish/DutchPortuguese/Italian/Finnish/Romanian/Polish and so on
-Voice guidance: Yes
-Support 2D/3D Map Views: Yes
-Dual Zone Function: Yes
DVD
-DVD Lens Brand: SANYO 860C
-Decoder: SUNPLUS 8202 VGQ
-Compatible Format: DVD, DVD-R,DVD-RW,HDVD,DVCD,MP3,MP4,CD-R,CD-RW,VCD,DIVX,WMA/JPEG
-Audio/Subtitle Language: English/French/Portuguese/German/Italian/Arabic/Russian
-Divx Title: Unicode/UTF8/ASCII
-Last-Position-Memory : Yes, expediently watch all kinds of disc continuously
Bluetooth
-Hands Free: yes
-A2DP (Bluetooth Stereo Music): Yes, can play stereo music through Bluetooth
-Phone Book Download: Yes, can download Phonebook from mobile to this unit
-Built-in Microphone : Yes on the frontpanel
Radio
-AM Frequency Range: 522-1620KHz
-AM Increment: 9KHz(EU)/10KHz(US)
-FM Tuning Range: 87.5-108MHz
-FM Increment: 0.05MHz(EU)/0.1MHz(US)
-FM Area: Europe/USA1/USA2/Russia/Japan
-Preset Stations: 30 (FM 3*6, AM 2*6)
iPod
-Compatible with iPhone /iPad: yes
-Charge the connected Device : yes
-Show Playlist on screen : yes
-Control iPhone from Screen: yes
-iphone audio input: yes, one ipod cable will be in parcel included
-iPhone video input: No, you can buy iphone video cable ES128 in our shop
USB
-Position: USB1 and USB2 on the back of the unit
-Capacity: 16GB
-Support MP5 Video: Yes, support 1080P RMVB Video
-Touch Music title to play directly : Yes
SD
-Position : On the front Panel
-Capacity : 16GB
Other
-Original VW UI: Yes
-Standard VW connector: Yes
-VMCD: yes, can save Tracks from CD to SD card to play
-Calendar: yes
-OPS Reader Display: Yes
-Backing Tracks Display: Yes
-A/C Control display: Yes
-OBD Display r: yes
Input
-AUX Video In: One
-Camera Video In : One
-Media USB IN :One
-AUX Audio In: R/L
-Radio Antenna Input: One
-GPS Antenna Input: One
Output
-Video Out: one
-Audio Out: RR/RL/FR/FL
-Surround Stereo Output: 4 x 50w
-Subwoofer Out: One
Control
-Steering Wheel Control: Yes
-Reverse Control: Yes
-Hand brake Control: Yes
-External iPod/iPhone Touch Control: Yes
Accessories
-User's Manual in English: One
-Power Cable with Special Potr: One
-Rear View Camera connecting Cable: One
-RCA Cable: One
-USB Cable: One
-IPOD Cable :One
-GPS Antenna: One
-4GB Micro SD Card as gift: One
-Touch pen :One
