0 NeutralAbout daraczg
- Birthday 05/30/1987
darko
golf 2 1.6D-GTI
7012 profile views
Ispravan, koristen manje od 30min. bez bad sectora, formatiran i spreman za rad. Moguca proba prije kupnje. Model Number: ST320LT025 Brand: SEAGATE Type: Hard Drive Capacity: 320GB RPM: 7200 Interface: SATA Size: 2.5 7M Dostava Zg, slanje postom. Moguce zamjene, cijena u zamjeni veca. Cijena 200kn Na pm ili 097 7777 174
Ispravnost odlicna Vrlo malo koristen Moguca proba prije kupnje Garancija vrijedi do 10. mj. 2015 Radi na 097, 098, 099 Kutija papiri, micro sd 4gb, 2 maske Procesor 1.0 ghz, 512mb rama, 5.0mp,... Android 4.1.2 http://www.gsmarena.com/samsung_galaxy_fame_s6810-5279.php Dostava za Zg, mogucnost slanja postom, autobusom. Moguce zamjene za razno, cijena u zamjeni veca. Cijena 700 kn Na pm ili 097 7777 174
SONY, PIONEER, KENWOOD, PANASONIC, JVC ISO KONEKTORI
daraczg replied to daraczg's topic in Ponuda :: Auto akustika
Bump -
Ispravan Moguca proba prije kupnje Speaker type : Subwoofer Impedance : 4 ohm Size : 10" (25 cm) Power handling capacity : 400 W RMS / 600 W max Frequency range : 25-2000 Hz Sensitivity : 89 dB (1W/1m) Magnet size : 156 mm (6,15"), 100 oz Outer diameter : 262 mm (10,31") Installation depth : 130 mm ( 5,11") Mounting hole : 234 mm (9,21") Weight : 6,7 kg (14,77 lb X-max : +- 9 mm (0,35") Dostava za zg, mogucnost slanja postom, autobusom. Moguce zamjene za razno, cijena u zamjeni veca. Cijena 400 kn. Na pm ili 097 7777 174
Bump -
Ispravnost odlicna Stanje prema slikama Moguca proba prije kupnje Spezifikationseinhaltung ATX12V 2.3/ EPS12V 2.92 Breite 15 cm Tiefe 16 cm Höhe 8.6 cm Stromversorgungsgerät: Einklappen - Eingangsspannung Wechselstrom 100-240 V Nötige Frequenz 50/60 Hz Ausgangsspannung +3.3, +5, ±12 V Angaben zu Ausgangsleistungsanschlüssen 1 x Stromversorgung: ATX, 24-polig, mit abnehmbarem 4-poligem Aufsatz 1 x Netzstecker P4 1 x Storm P8 1 x 8-poliger PCI Express-Stromanschluss mit abnehmbarem 2-poligem Abschnitt 1 x PCI-Express-Stromversorgung, 6-polig 5 x interne Stromversorgung, 4-polig 5 x SATA-Anschluss (22 Pin) 2 x 4-Pin-Mini-Stromversorgungsstecker Elektrischer Strom max. 7 A Leistungskapazität 450 Watt Ausgangsstrom +3.3V - 24 A +5V - 20 A +12V1 - 18 A +12V2 - 18 A +12V3 - 18 A +12V4 - 18 A -12V - 0.3 A +5VSB - 3 A 80-PLUS-Zertifizierung 80 PLUS Bronze 80 PLUS Certification 80 PLUS Bronze Verschiedenes: Einklappen - Enthaltene Kabel 1 x Stromkabel - extern Kühlsystem 120-mm-Lüfter Kennzeichnung CE, TUV, CB, FCC, RoHS, 80 PLUS Bronze, WEEE Besonderheiten Überhitzungsschutz, Überstromschutz, Überspannungsschutz, Over Power Protection, Unterspannungsschutz, Kurzschlussschutz, drei 12-V-Ausgänge Produktzertifizierungen CE, TUV, CB, FCC, RoHS, 80 PLUS Bronze, WEEE Kennzeichnung TUV, CB, FCC, RoHS, WEEE Kennzeichnung CE, TUV, CB, FCC, RoHS, WEEE ENERGY STAR-qualifiziert Ja ENERGY STAR Ja Transportgewicht 2.9 kg Dostava za zg, mogucnost slanja postom, autobusom. Moguce zamjene za razno cijena u zamjeni veca. Cijena 200 kn Na pm ili 097 7777 174
Ispravan Punjac je orginalan i nije popravljan Toshiba PA3290E-3AC3 Input AC 100-240V, 50-60Hz Output Voltage 19V Output Current 6.5A Power 120W Connector Size 5.5 * 2.5mm Kompatibilan sa: Satellite A200 series, Satellite A210 series, Satellite P200 series, Satellite Pro A200 Series, Satellite Pro P200 Series, Satellite X200 series Dostava za Zg, mogucnost slanja postom, autobusom. Cijena 150kn Na pm ili 097 7777 174
Ispravni Moguca proba prije kupnje Obe plocice su 100 kn Manufacturer Hynix Manufacturer Part # HYMP512S64CP8-Y5 AB-C Memory Type SODIMM Capacity 1GB Pins 200 Pin Bus Type PC-5300 Cycle Time 6ns Cas CL5 Data Transfer Rate 667Mhz Memory Clock 166Mhz Voltage 1.8 Dostava za Zg, mogucnost slanja postom, autobusom. Cijena 100kn Na pm ili 097 7777 174
Ispravnost odlicna Stanje prema slikama Moguca proba prije kupnje Izlazi za pojacalo Sub control Tuner Type SSIR-EXA ABC (Automatic Bandwidth Control) BTM (Best Tuning Memory) RDS EON Tuner Station Presets FM 18.0 MW 6.0 LW 6.0 CD Player Drive-S Mechanism for 1 x CD CD-R Playback capability CD-RW Playback capability MP3 Playback capability ID3 Tag display (Track, Artist, Album name CD Text display Title Scroll (CD Text) Repeat Play Shuffle Play Specification Audio Digital Filter 8 fs D/A Converter 1 bit Frequency Response (Hz) 10 - 20,000 Tolerance (dB) +/-1 Signal to Noise Ratio (dB) 120.0 Amplifier S-MOSFET Output Stage Output Power, DIN 45324 at 4 ohm (W) 4 x 26 Max. Output Power, 1 kHz at 4 ohm (W) 4 x 50 EQ 3 (3 Band Equalizer) YES Pre-amp Output (stereo RCA) 1 Max. Pre-amp output level (V) 2.0 Sub-Switch (rear out / sub out switchable) Selectable Low Pass Filter in Sub-mode Sub Volume Control in Sub-mode Safety Commander Interface 3.5 mm Mini Jack Others Display Type 13 Segment Display Colour 1 colour Display Dimmer Key Illumination red Sensor for IR Commander Removable Front Panel Integrated Clock 24 h Telephone Attenuator ISO Connector Installation Angle (degrees) 0 - 45 Dimensions Width (mm) - approx. 178.0 Height (mm) - approx. 50.0 Depth (mm) - approx. 179.0 Dostava za Zg, mogucnost slanja postom, autobusom. Moguce zamjene za razno, cijena u zamjeni veca. Cijena 200kn Na pm ili 097 7777 174
Laptop je za dijelove Bez punjaca,baterije,harda i rama Sve ostalo komplet za 350 kn Processor type : AMD Turion™ 64 X2 Dual-Core Mobile Technology TL-60 clock speed : 2.0 GHz Operating System / Platform Windows Vista® Home Premium Edition System memory standard : 2,048 (1,024 + 1,024) MB maximum expandability : 4,096 MB technology : DDR2 RAM (667 MHz) Hard disk capacity : 200 GB certification : S.M.A.R.T. drive rotation : 5,400 rpm DVD Super Multi drive (Double Layer) compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-R(DL), DVD-RW, DVD+R, DVD+R(DL), DVD+RW, DVD-RAM maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 4x CD-RW, 10x HS CD-RW, 10x US CD-RW, 8x DVD-R, 4x DVD-R (Double Layer), 4x DVD-RW, 8x DVD+R, 4x DVD+R (Double Layer), 4x DVD+RW, 5x DVD-RAM type : DVD Super Multi (Double Layer) drive Display size : 15.4 " type : Toshiba TruBrite® WXGA TFT High Brightness display internal resolution : 1,280 x 800 Graphics adapter type : ATI Mobility Radeon™ HD 2600 supporting HyperMemory™ technology memory amount : 512 MB dedicated VRAM (up to 1.279 MB total available graphics memory using HyperMemory™ technology with 2 GB system memory) memory type : DDR Video RAM (resp. DDR Video RAM and DDR system memory combined) connected bus : 16x PCI Express Internal video modes The following internal video modes are supported: : resolution : 1,280 x 800 , maximum number of colours : 16.7 million Max. external video modes max. resolution : 2,048 x 1,536 max. colours : 4.3 billion max. refresh rate : 85 Hz non-interlaced resolution with max. refresh rate : 1,600 x 1,200 Interfaces 1 × DC-in 1 × external monitor 1 × RJ-11 1 × RJ-45 1 × TV-out (S-video) 1 × i.LINK® (IEEE 1394) 1 × external microphone 1 × headphone (stereo) 1 × 5-in-1 Bridge Media slot (supports SD™ Cards, Memory Stick®, Memory Stick Pro™, MultiMedia Card™, xD-Picture Card™) 4 (Left 2, Right 2) × USB 2.0 1 × integrated 1.3 Megapixels Video Camera Expansion 2 × memory slots 1 × Express Card™ slot Wireless communication Compliancy : Wi-Fi® Network Support : 802.11b/g integrated Manufacturer : Atheros Wireless Technology : Wireless LAN Manufacturer : Taiyo-Yuden Wireless Technology : Bluetooth® Version : 2.0 + EDR Wired communication topology : international V.92 modem speed : 56 Kbps data and 14.4 Kbps fax topology : Ethernet LAN speed : 10BASE-T/100BASE-TX Sound system supported audio format : 24-bit stereo supported sound standards : MIDI support speakers : built-in stereo speakers manufacturer : Toshiba Bass Enhanced Sound System with Dolby® Sound Room™ Keyboard Keys : 87 Windows® keys : 2 Pointing device type : Dual mode Pad Battery technology : lithium-ion maximum life : currently no official Windows Vista® battery benchmark result available AC adapter input voltage : autosensing AC adapter (100/240 V) for worldwide usage output voltage : 19 V output current : 6.32 A Physical dimensions W x L x H : 362 x 267.8 x 33.5 (front) / 39.3 (rear) mm weight : starting at 2.7 kg Warranty 1-year international warranty. Upgrade your standard warranty with Toshiba warranty extension and uplift packs. Contact your nearest Toshiba Authorised Reseller for details. Bundled hardware AC adapter Bundled software Connectivity Doctor Norton Internet Security™ 2007 (includes free Internet updates for 90 days) Toshiba Assist Toshiba Bluetooth® Monitor Toshiba Bluetooth® Stack Toshiba Camera Assistant Software Toshiba ConfigFree™ Toshiba DVD Player Toshiba Disc Creator Toshiba Speech System Toshiba Supervisor Password Utility Toshiba User's Manual Toshiba Value Added Package Toshiba utilities and drivers Ulead® DVD MovieWriter® for TOSHIBA Toshiba EasyMedia Bluetooth® 2.0 with EDR Built-in Web Camera & microphone Diversity Antenna Easy Keys Instant DVD/CD (Windows HotStart) Integrated Bridge Media Adapter Internal HD 720p support Smart Display Support Toshiba ConfigFree™ Toshiba Flash Cards Security features BIOS password Wireless LAN switch main battery pack (by sliding latch) main hard disk (by screw) main memory (by screw) slot for Kensington Cable Lock supervisor password system password security user password Special features AMD PowerNow!™ Technology HD Audio supporting Microsoft® Windows® HotStart™ for instant-on entertainment Multimedia Bar with 6 Easy Keys (Internet Browser, CD/DVD launcher, Play/Pause, Stop, Rewind, Forward) SM BIOS compliant integrated 1.3 Megapixels Video Camera for Video over IP integrated microphone for Voice over IP Dostava za Zg, mogucnost slanja postom, autobusom. Moguce zamjene za razno, cijena u zamjeni veca. Cijena 350 kn Na pm ili 097 7777 174
daraczg posted a topic in Ponuda :: Auto akustika
Konektori su polovni i potpuno ispravni Cijena je 50 kn po komadu Dostava za Zg, moguce slanje postom, autobusom. Na pm ili 097 7777 174 -
Lock
