u2boy4ever
About u2boy4ever
    domagoj
    passat
    auti
  1. u2boy4ever
    xenon na b6
    aftermarket koja je forasa passatom i strujom? dali itko zna kako to spojiti?
  2. u2boy4ever
    xenon na b6
    na passata b6 2006g stavio sam xenon, ako ga spojim direktno preko utičnica, radi par sekundi i ugasi ga, ako ga spojim preko canbus decodera radi normalno dok ne upalim auto,onda nakon par minuta počme treperiti, ako ga spojim preko xenon releja radi super 20 dana i onda izgori relej, tj spojevi na releju. ima li tko riješenje za ovaj problem? stavlja sam i 35 i 55w xenone
  3. u2boy4ever
    kupujem felge i gume
    za passata b6 17ke,sa dobrim gumama, do 2500kn ponude na pm
  4. u2boy4ever
    b6 se guši
    passat b6 se guši iznad 2500 obrtaja,kao da je u limp modu, pogotovo uzbrdo nijedna lampa ne svijetli evo diagnostike Wednesday,20,May,2015,17:50:01:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.0.0 Data version: 20130910 VIN: WVWZZZ3CZ6P154227 License Plate: 553AAQ Mileage: 218450km-135738mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C (3C0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D VIN: WVWZZZ3CZ6P154227 Mileage: 218450km/135738miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 03G 906 018 EJ HW: 03G 906 018 CH Component: R4 2.0l PPD1.5 G 9633 Revision: --H05--- Serial number: VWZCZ000000000 Coding: 0000072 Shop #: WSC 06958 995 88324 VCID: 71E9334F685CC1966BD-8024 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb Part No SW: 3C0 614 095 P HW: 3C0 614 095 P Component: ESP 440 C2 H015 0003 Revision: H015 Serial number: 0658581127 Coding: 0013581 Shop #: WSC 08250 995 90517 VCID: 2F6DF537BEE897663D9-807A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA Component: ClimatronicPQ46 050 0404 Revision: 00050005 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 60CF460BB3B6781EF43-8035 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 J HW: 3C0 937 049 J Component: Bordnetz-SG H37 1301 Revision: 00H37000 Serial number: 00000003751260 Coding: A1800F0700041A00000A00000F00000000095D435C0000 Shop #: WSC 00028 028 00001 VCID: 306FF64BA3D6889E243-8065 Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB Component: Wischer VW461 001 0101 Coding: 00063445 Shop #: WSC 00028 3 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 2 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 11.95 V ON ON OFF OFF OFF 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 12.00 V ON ON OFF OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 157 Mileage: 208078 km Time Indication: 0 Freeze Frame: ON Voltage: 12.05 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 J HW: 3C0 909 605 J Component: 04 AIRBAG VW8 029 2521 Revision: 09029000 Serial number: 003A2PRXLWUB Coding: 0012340 Shop #: WSC 00028 028 00001 VCID: 2D51EF3FB4E4E5760F5-8078 Subsystem 1 - Serial number: 6332MSME0D71380E Subsystem 2 - Serial number: 6342MSME0D41425B Subsystem 3 - Serial number: 6351HTS61IK6MKJ2 Subsystem 4 - Serial number: 6361HTS61IK6AJJ2 Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 A HW: 3C0 953 549 A Component: Lenksäulenmodul 005 0010 Revision: 00005000 Serial number: 3C5953507B Coding: 0000011 Shop #: WSC 00028 028 00001 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 851 M HW: 3C0 920 851 M Component: KOMBIINSTRUMENT VD1 4242 Revision: V0042000 Serial number: 00000000000000 Coding: 0002103 Shop #: WSC 69550 995 93882 VCID: 2C57E23B8FFEEC7E18B-8079 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C05C140685 Coding: 3DFD2C04C21002 Shop #: WSC 00028 028 00001 VCID: 2149030FF83C3116BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 M HW: 3C0 959 433 M Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 03009 425 94161 VCID: 3467FA5B57CEB4BE40B-8061 Subsystem 1 - Part No: 3C0 905 861 H Component: ELV 028 0380 3C0905861H ELV 028 0380 1 Fault Found: 02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 170 Mileage: 215885 km Time Indication: 0 Date: 2000.00.00 Time: 13:19:30 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2365 Coding: 0000181 Shop #: WSC 00028 028 00001 VCID: 3663C05341B2A6AE7EF-8063 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 M HW: 3C0 959 433 M Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 00910A0801860E76300416177008CF0B603CA0 Shop #: WSC 03009 425 94161 VCID: 3467FA5B57CEB4BE40B-8061 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2365 Coding: 0000180 Shop #: WSC 00028 028 00001 VCID: 377DCD5746B85FA6659-8062 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000011 Shop #: WSC 08250 995 90517 VCID: 2149030FF83C3116BBD-8074 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No: 1K0 035 186 P Component: Radio GR0 015 0019 Revision: 0001503S Serial number: VWZ2Z2E3302972 Coding: 0020202 Shop #: WSC 00028 028 00001 VCID: 3365F94752C0B386591-8066 1 Fault Found: 00857 - CD Changer Unit (R41) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 3365F94752C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 F Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 00028 028 00001 VCID: 3467FA5B57CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D51EF3FB4E4E5760F5-8078 No fault code found. End ---------------------------------------------------------------------
  5. u2boy4ever
    passat b6 gubi snagu
    robby ovori novu temu e sad, kakvi su ovi setovi za mjenjat brtve u njoj, kao neki reparatur kitovi? i dali postoji ikakav način za provjerit je, nije problem ni uzet ali opet da sam bar siguran da je do nje.. i nije mi jasno zašto ima veze koliko goriva ima u tanku
  6. u2boy4ever
    passat b6 zamjena cagera
    a za bijeli?
  7. u2boy4ever
    bijeli ili color po mogućnosti...
  8. u2boy4ever
    ček ček nisam vas skužio kako provjeriti koji sigurno pašu na moj? tj dali svaki paše? i dali su potrbni kakvi moduli, kodiranje ili slično? e da,moj passat nema komande na volanu, oće mi radit display i sve?
  9. u2boy4ever
    to je šta? kako sigurno ispitat jeli do nje?
  10. u2boy4ever
    auto spajano na dijagnostiku nema grešaka nikakvih, sve radi uredno,nije u safe modu ima tko ideju?
  11. u2boy4ever
    nitko nikad čuo?
  12. passat 2006g. 2.0tdi ima obični cager bez putnog računala i slično dali se može staviti recimo onaj sa displayom u sredini ? tj koji odgovara umjesto ovoga i šta je sa kilometražom?
  13. u2boy4ever
    i dalje stoji pitanje kako? imam dijagnostiku ali gdje očitava dali je u safe modu?
  14. Nije ti do sajle. imao sam isti problem. 3 moguća su riješenja 1. udariš dlanom par puta vanjsku ručku 2. istovremeno povuci i sa unutranje i sa vanjske strane kvaku 3. rastavi tapecirung udari par puta od lim kod brave meni svaki put upali treći način ali mi se to više ne događa. događa se uglavnom kad stisneš otključavanje i motorika nije odradila svoj posa do kraja a ti povučeš ručku u prazno mikroprekidač se zabuca i to ti je lijek
  15. u2boy4ever
    Naravno da ima taj model... 120ps Znači uglavnom ima lampica za pločice ali meni su diskovi kraju a mislim da za njih nema... valjda nisu skupi Jeli tko zna kako provjeriti jeli safe mode ili šta?
