0v3rl0rd
About 0v3rl0rd
  • Birthday 05/07/1987
    Marko
    Golf VI 1,6 TDI
1182 profile views
  1. Probao sam taj "reset limit" za podizače, ovako: otvorio prozor do kraja, držao 10 sekundi. Onda zatvorio prozor, i držao 10 sekundi. Probao sam par varijanti toga, nula bodova. Problem je i, a to sam malo prije skužio, da ne želi nekad (većinom) čak niti onaj "kratki" klik prihvatiti... koma Uglavnom, imam ja VCDS, i napravio sam auto-scan... bacilo mi je ovo (izrezao sam ostatak jer su ovo greške): 09-Cent. Elect. -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 086 M HW: 1K0 937 086 M Component: BCM PQ35 M 110 0651 Revision: 00110 AC Coding: 40180A3AE8251AC0400800C8740081E44B510288432D8520648087200041 Shop #: WSC 01357 011 00200 VCID: 3A4F785C67F50EE73F-806E Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB Component: Wischer 23071 26 0512 Coding: 009795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 280711 05 54 0403 Coding: 0630AD 2 Faults Found: 00061 - Footwell Lights 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 194 Reset counter: 147 Mileage: 109814 km Time Indication: 0 Date: 2017.03.09 Time: 19:08:07 Freeze Frame: Term 15 Off Voltage: 12.55 V OFF ON Term 50 Off OFF OFF 01565 - Luggage Compartment Light (W3) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 194 Reset counter: 147 Mileage: 109814 km Time Indication: 0 Date: 2017.03.09 Time: 19:08:07 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 5K0 959 701 H HW: 5K0 959 701 H Component: Tuer-SG 009 2105 Coding: 0131252 Shop #: WSC 01357 011 00200 VCID: 37408655BBE63CD227-8062 3 Faults Found: 00912 - Window Regulator Switch; Front Left (E40) 008 - Implausible Signal 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent 00914 - Window Regulator Switch; Rear Left; Driver (E53) 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 1K0 907 951 Component: Batt.regelung H43 1620 Serial number: 190711F2000851 Coding: 030B185A Shop #: WSC 01357 011 00200 VCID: 71860A834380D06477-8024 Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A Component: J367-BDM H07 0180 Serial number: 00000000008900107750 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 167 Mileage: 110209 km Time Indication: 0 Date: 2017.03.25 Time: 07:36:09 Ova greška za "footwell" i za "luggage compartment" je zato jer sam izvadio žarulje (sa namjerom da ih zamjenim LED-icama kad mi stignu), stigle su (2 vrste) i jedna od njih mi radi kratki spoj (izvadio sam ih). Vjerojatno se zato i pojavila ova greška na bateriji. Izbrisao sam geške (Delete DCT's) preko VCDS-a i nestale su te greške vezane za footwell, luggage, i bateriju, ali i dalje ostaje ova za "central elecrtonics".
  2. Preko čega ti gledaš te greške? Ja sam spojio OBD na auto i preko bluetootha na mobitel - aplikacije (Torque, EOBD Facile) mi ne izbacuju nikakvu grešku - za sada. Jutros nije bilo toplo a imao sam grešku - po meni onda nije problem u vrućini. Jutros je problem bio sličan: radio je jedino vozačev prozor, a sa vozačeve kontrole nisam mogao kontrolirati nijedan prozor osim vozačevog. Sve ostale kontrole normalno rade
  3. Kako misliš da nema nikakve greške? Provjeravao negdje ili? Sve si mislim kad mi se to sutra ponovi da ću trebati rastaviti vrata (skinuti onu veliku plastičnu ploču)... Samo mi je da ne slomim nešto - nisam nikad to skidao sa vrata, a znam da se one zakačke daju lako slomiti.
  4. Imam problema sa podizačima na mom G6. Par informacija: 1) Imam i prednje i zadnje podizače 2) Inače je sve radilo osim: kad na VOZAČEVOJ strani stisnem automatsko (do kraja) spuštanje SUVOZAČEVOG prozora - ne šljaka - tj. spusti ga onoliko koliko dugo držim pritisnut gumb. Ali to me nije previše zamaralo - do danas. 3) Krenulo toplo vrijeme... danas sam ostavio auto na parkingu, na suncu... zblesalo se sve, nijedan prozor nisam mogao otvoriti... radilo je na mahove, doslovce. Ako netko ima bilo koji savjet ili neku korisnu informaciju - hvala
  5. Svaka čast, hvala na pomoći. Pokuati ću to srediti čim prije, dok mi stigne kutijica u koju ću taj modul staviti. A ti ako ikad budeš u Rovinju javi i ima pivo
  6. Prvo, unaprijed se ispričavam na povećem broju pitanja. Dop****** i meni svaki put klikati gumb, i odlučio si i ja složiti to gaenje start-stopa Stigao mi relej i pospajao žice za programiranje ovako: NO > lampa+ COM > akumulator+ DC+ > akumulator+ DC- > akumulator- LAMPA- > akumulator- Isprogramirao "mod 3" koji, koliko sam skužio, radi ovako: kod davanja kontakta relej odbrojava vrijeme T1 i onda zatvara krug (tj. "pali žarulju") za T2 sekundi, i na kraju kad istekne T2 onda gasi žarulju. Stvar ljaka (VIDEO) Međutim, nakon ta se taj proces odvrti, na displeju releja ostane upaljeno "--03" i blica ledica "MD" a crvena ledica pri donjem desnom kutu svijetli. PITANJE 1: Nakon tog procesa modul ostane upaljen za cijelo vrijeme vožnje!? Se može tome nekako doskočiti, neto tipa da se relej ugasi kad odvrti taj proces? @zvonimir, ako sam dobro shvatio iz tvog posta, u autu tražim taj E693 prekidač i crno-zelenu te rozo-sivu žicu na koje spojim NO i COM na releju. PITANJE 2: Gdje se taj "prekidač" uopće nalazi? Da li sa "donje" strane start-stop gumba ili pak negdje oko osigurača ili negdje drugdje? Da li je OVO način kako da poskidam tu centralnu konzolu sa gumbima? PITANJE 3: Nije mi jasan dio "Na DC+ dovede 12V sa +15 kontakta (preko kontakt brave) sa bilo koje pozicije (radio, OBD utičnica, upaljač....)"? Slijedeće, vidim da @glogi spominje "osigurač adapter". PITANJE 4: ta sve trebam kupiti? Gdje to trebam staviti i kako spojiti? PITANJE 5: Kako je najbolje podesiti vremena T1 i T2? Kužim da se za T1 stavi kako nama odgovara, ali eto pitam za sugestije Vezano za T2 - koliko je dovoljno da krug bude zatvoren da auto "prihvati" klik? Unaprijed hvala na odgovorima
  7. 0v3rl0rd
    Osvjetljenje pod nogama g6
    Aha, dobro, bitno da mi se ne "pričinjava"... nije da je to previše važno, ali, riješiti ćemo to već
  8. 0v3rl0rd
    Pozdrav Pitanje, kako si kodiranjem to riješio? Šta se tiče tih "footwell" svijetla ja imam sličan problem - stavio sam na 35% (mislim da je to minimum, a da nije skroz ugašeno). I u vožnji mi se dešava da samo odjednom, na sekundu, zasvijetle na 100% i onda se vrate na 35%. Za sad nisam prokužio KAD se to točno dešava niti šta točno "pokrene" takvo ponašanje... u konstantnoj vožnji na autoputu, bez stajanja 400 km, desilo mi se to 3 puta (da sam skužio, moguće još koji put bez da primijetim). Ako netko ima neku ideju slušam Za koji dan mi stiže kabel od Sklad-a pa ću i taj dio pokušati proučiti.
  9. 0v3rl0rd
    Golf 6 kada prtljaznika
    @@rapajic.st: Hvala na withcar-u. OVO mi se čini kao da bi moglo odgovarati. Iako, 350 kn nije malo za komad gume. Al opet nije kao original @@dr.restaurator: Baš sam takvu kakvu opisuješ (plastičnu) i imao za Clio. Moja je isto bila malo deformirana (poslana je u "roli") ali se kroz par dana izravnala skroz - baš radi toga šta je cijela površina gepeka većinom puna. Isto je pisalo da stvari ne "kližu" po njoj, ali jbg kad je to 98% plastika - klizi. Ali nije mi to smetalo jer u 99% slučajeva mi je gepek popunjen - ništa ne klizi nikud. Onaj 1% je prazan. Tako da mi je ta zaštita potpuno nebitan/nepotreban detalj. Ovako je to izgledalo na mom Cliu: Ali kako si i rekao, po slici (link) mislim da je to ta kakva bi meni trebala. @: Vezano za OEM kadu - da, već sam par puta čuo da je spužvasta i trošna, a to mi nikako ne odgovara. Hvala na upozorenju
  10. 0v3rl0rd
    Nisam pitao u ovlaštenom, baš jer sumnjam da bi cijena bila ispod 400/500 kn. Paaa, od Siluxa sam bio uzeo za Renault Clio - i pasale su savršeno, u milimetar. Zato mislim da kad bih znao model da bi moglo odgovarati. Taj materijal mi čak i odgovara više nego guma - ne skliže se previše a opet nije da se "zalijepe" stvari na njega. Vezano za to "vađenje tapecirunga" - logično je i meni to da ne vadim ništa, ali kako mi je njihov zaposlenik rekao "jedna kadica je za vozila koja imaju rezervni kotač a druga bez" (vezano za OVU i OVU) pa sam zato specificirao da imam rezervni kotač i da ne mislim ništa vaditi Bilo bi od pomoći ako itko zna ili je kupovao takvu kadu iz neke trgovine ili nešto da da koji savjet
  11. Pozdrav Trazio sam po forumu ali bezuspjesno. U potrazi sam za kadicom przljažnika. Auto je Golf 6 1.6 TDI, Style oprema. U gepeku imam rezervnu gumu. Gepek je ovaj: Naručio sam iz Silux-a (po preporuci prodavača) ovu kadicu: Model 9513WB31. Međutim, kada je predugačka (crvene strelice) a ovi utori (plave strelice) uopće ne odgovaraju na moj Golf. Kadicu su uzeli natrag i rekli da je greška u katalogu i da će vratiti novac. Nema problema po tom pitanju. Nego ja i dalje trebam tu kadu Ono što meni treba jest da tu kadu samo stavim u gepek: ne bih vadio gumu, niti onaj tvornički "tepih/ploču", nit ništa ispod. Znači, kakav je gepek na gornjoj slici, samo bih iznad toga stavio kadu. Sad, na njihovoj stranici sam našao slijedeće: LINK - Golf V 03-09 zaštita: u opisu stoji da odgovara za vozila Volkswagen Golf 2003-2008 (V), Volkswagen Golf 2008-2012 (VI). Da li neto ima koju ideju/savjet o tome koju kadu i gdje ju kupiti a da odgovara za auto? Ne bih neku univerzalnu. Hvala
  12. 0v3rl0rd
    VW Navigacija
    Pozdrav Imam par pitanja vezana za RNS 310 i navigaciju. Naime, na svega par mjesta sam uspio pronaći informacije o tome "kako" i "šta" spržiti. Uglavnom, na kompovima imam instalirane Win7 i Win10, i na oba kompa mi prilikom pokretanja CDRWIN 5 baca grešku (error:the driver could not be initiated). Stoga sam CD spržio programom IMGburn. Spržio sam dvije verzije CD-a: (1) cd2-EUR_IRP-VW_RNS310_V4.cdr >> 830 MB (2) CHS-VW_RNS310_V4.cdr >> 171 MB Oba CD-a sam spržio na brzini 1X. Kad ih ubacim u svoj RNS310 dobijem gešku (error: copied CD. The navigation data on the CD cannot be used") i onda mi fino ispljune CD. Po tutorialima vidim da se u CDRWIN 5 programu treba označiti opcija "RW Data", ali otkud god taj program skine (a da je verzija 5) baca mi grešku kod otvaranja. Onda sam skinuo CDRWIN najnoviju verziju (10) i na njoj uopće nema te "RW data" opcije. Ima netko nekakvu ideju ili savjet po pitanju te navigacije? PS onda mi je palo na pamet pogledati nešto tipa ovo: LINK. Pa ako netko ima savjet ili nešto pametno za reći po pitanju tih "android" radia/navigacija - slušam Ima neka "posebna" sa kojom: - tipke na volanu ostanu funkcionalne - podržava prikaz parkirnih senzora kao kod originala - podržava interakciju sa Climatronic-om - uglavnom podržava sve funkcije auta koje podržava originalna radio/navigacija? Hvala
  13. 0v3rl0rd
    golf 6 1.6 tdi bluemotion user manual
    Pozdrav svima. Novi sam član i ovo mi je prvi post. Imao sam poteškoće u pronalaženju korisničkog priručnika bilo na hrvatski bilo na engleski. Hvala članu @polic na kvadrat - on mi je proslijedio poslikanu hrvatsku knjižicu. U međuvremenu sam uspio sa neta (VW UK) skinuti manual na engleskom jeziku... caka je u tome da taj manual nema onaj kratki sadržaj na prvoj stranici, tj. nije kao "prava" knjiga = nema numeriran sadržaj po stranicama: ima numerirane stranice ali ne možeš brzim pregledom sadržaja/indexa sa prve stranice reći da se na "stranici toj-i-toj nalazi poglavlje o ABS-u". Uglavnom, bolje izdanje od toga u digitalnom obliku nisam uspio naći. Ako nekom treba nek mi se javi u PM i šaljem. Nadam se da će bar nekome pomoći
