toda81
0 NeutralAbout toda81
Vlada
VW Touran 1.9 77kw BKC 2005. god.
Kodiranje instrument table golf 4
toda81 replied to raxivan94's topic in Volkswagen :: Tehnički kutak
Koji program preporučuje te da kupim od sklad66, a da radi na golf 4 1.o, 2001. God. i za vw touran 1.9 2005. God BKC motor. Za golf 4 mi je potreban da bih sada ugasio imobilajzer, a za vw touran-a za kodiranje novog ključa. Hvala unapred na odgovorima -
Škoda Karoq 2020. god. 1.6 dizel - uparivanje svetala
toda81 replied to toda81's topic in Volkswagen :: Volkswagen kvarovi
Auto ne vidi farove i zmigavce. Odjavljeni sa auta. Treba module farova da doda na gataway -
toda81 started following Povremeni problem sa paljenjem and Škoda Karoq 2020. god. 1.6 dizel - uparivanje svetala
toda81 posted a topic in Volkswagen :: Volkswagen kvarovi
Da li mozda neko ima rešenje za ovaj problem? U pitanju je Škoda Karoq 2020. god. 1.6 dizel. Kako UPARITI svetla sa autom? Ovo je log na VCDS: Sunday,01,October,2023,22:13:01:16365 VIN: TMBJG7NU1LJ007008 License Plate: Mileage: 195859km-121701mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NU-SK37 (3Q0) Scan: 01 02 03 05 08 09 10 13 15 17 19 29 2B 36 39 3C 42 44 4B 52 5F 6D 75 A5 BB BC D6 D7 D8 D9 VIN: TMBJG7NU1LJ007008 Mileage: 195859km-121701miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 29-Left Light -- Status: Cannot be reached 0100 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: Cannot be reached 0100 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100 D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100 D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100 D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG Component: BCM MQBAB H H40 0312 Serial number: 01001918002178 Dataset Number: V03935307PL 0001 Coding: 060000000000000000000000000000000000000000000000000000000000 Shop #: WSC 00040 790 00030 ASAM Dataset: EV_BCMMQB 020001 ROD: EV_BCMBOSCH_020_VW26.rod VCID: 015F8519318AF4D2005-8054 Rain/Light Recognition Sensor: Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555 Component: G397_RLFSS H06 0002 Serial number: 23245413X81A955555A0 Coding: 80006E Steering Column Switch: Subsystem 2 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A Component: Lenks.Modul H13 0170 Serial number: 0100270620190C301779 3 Faults Found: 541204 - Databus U1123 00 [008] - Received Error Message [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 207 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: Not operated Position lamps: Not operated Automatic high beam assist: operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.8 V Outside temperature: 16.0 �C 568342 - Databus U1123 00 [009] - Received Error Message [LCM rechts - Blinker defekt] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:24 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.8 V Outside temperature: 16.0 �C 568836 - Databus U1121 00 [009] - Missing Message [LWR AFS - Kein Signal/Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:51 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.9 V Outside temperature: 16.0 �C ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 565 920 790 C HW: 565 920 790 C Component: KOMBI 502 4191 Coding: 00A40C1E6F8C0008018C77031001000880200000 Shop #: WSC 80093 222 69422 ASAM Dataset: EV_DashBoardVDDMQBA0 001042 ROD: EV_DashBoardVDDMQBA0_001_VW37.rod VCID: 1E65DE65A0342B2A1D7-804A 1 Fault Found: 16777126 - Function Restricted due to Interrupted Communications U1110 00 [009] - - [BAP_IAA_PSO_0x82 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:50 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C Component: GW MQB High 521 5388 Serial number: 29061910803182 Dataset Number: V03935300AP 0001 Coding: 030100045F087300231002D2100F00010001070000000000000000000000 Shop #: WSC 00040 790 00031 GVL: 01463C000800060040DC80008000C8000C00C003000200000000000000000000 ASAM Dataset: EV_GatewNF 013026 ROD: EV_GatewNF_VW37.rod VCID: 70B9D0DD0A20ED5AFFB-8024 Generator: Component: 4-01-13-01-04 Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E Component: E221__MFL-PR6 H03 0180 Serial number: 000000000C0511090719 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1051 Serial number: 7588600300190702095E 6 Faults Found: 131714 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x82] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131715 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x83] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131734 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x96] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131735 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x97] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131736 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x98] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131737 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x99] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On ------------------------------------------------------------------------------- Address 29: Left Light Cannot be reached ------------------------------------------------------------------------------- Address 39: Right Light Cannot be reached ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E Component: FCM MQB Low 003 0367 Serial number: 24051911603413 Dataset Number: V03935295XK 0001 Coding: 000000040900052200003501190000000000000000000000000000000000 Shop #: WSC 00040 790 00030 ASAM Dataset: EV_MultiModulContiVW48X 003003 ROD: EV_MultiModulContiVW48X_003.rod VCID: 372B2BC12FCE7A62FE1-8062 4 Faults Found: 0037 - Databus for Front Lighting U12EB 00 [009] - Additional Installations Detected [CAN_AFS_multiple_plug_LED_Leimo_identified] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 13706046 - Databus U1123 00 [137] - Received Error Message [LV_Abblendlicht_li_def received error value] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 13706047 - Databus U1123 00 [137] - Received Error Message [LV_Abblendlicht_re_def received error value] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 0032 - Headlight C107E 54 [137] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 ------------------------------------------------------------------------------- Address BB: Door Rear Drv Cannot be reached ------------------------------------------------------------------------------- Address BC: Door Rear Pass Cannot be reached ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A Component: LED1L H07 0009 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 025D8A15348CEFCA19F-8056 2 Faults Found: 0338 - Databus U1121 00 [175] - Missing Message [can message LCM_Soll_Fkt missing] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 0773 - Supply Voltage for Low-Beam C11FD 13 [174] - Open Circuit MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A Component: LED1R H07 0009 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 025D8A15348CEFCA19F-8056 2 Faults Found: 0338 - Databus U1121 00 [175] - Missing Message [can message LCM_Soll_Fkt missing] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 0773 - Supply Voltage for Low-Beam C11FD 13 [174] - Open Circuit MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 ------------------------------------------------------------------------------- Address D8: LED HeadL. Pwr Left Cannot be reached ------------------------------------------------------------------------------- Address D9: LED HeadL. Pwr Right Cannot be reached End----------(Elapsed Time: 01:56, VBatt start/end: 13.0V/13.0V)----------- -
Auto sam kupio pre oko 2 godine. Kupio ga je moj prijatelj koji zivi u Austriji. Kupljen je od vlasnika koji je imao 3 tourana, tj. moj koji je 2005. god, drugi je 2010. i treci 2016. I taj 2010. je bio na prodaju, ali ja nisam imao dovoljno novca pa sam kupio 2006. Moj auto je bukvalno vozen do 2010. godine kada je kupio drugog tourana i posle toga ga je ocigledno koristio za prevoz svega i svacega i bio jeu nekoj travi. Kako sam dosao do tog zakljucka? Kada sam preuzimao auto sa carine ja sam se bas razocarao jer je karoserija , skroz u krug, do visine polovine vrata puna nekih zutih tackica, cak i ona olasticna lajsna. Ja sam to nekako sredio tako sto sam dva dana ludacki trljao polir pastom sve te delove i skinuo sam sve te zute tackice koje su bile nalik koroziji. Pored toga sam imaoproblem sa malim hladnjakom jer je rashladna tecnost bila kao mulj pa sam sa kumom par puta ispirao vodom ceo sistem i nekako sto to sredili. Bukvalno par dana kada sam ga dovezao kuci iregistrovao, odjednom je prestala da radi turbina i auto je jedva vukao, tj jedva sam nekako dolazio maksimalno do 90km/h. Posle vise pokusaja i pogresne kupovine map senzora i vakuum jedinice ili kako se vec zove, otisao sam kod dobrog elektricara koji je pronasao da je problem sto su pinovi na motornom racunaru oksidirali i on jeto sredio i turbina je proradila. Klimu mu nije radila od samog pocetka ito mi je sredio moj elektricar, a upitanju je bila samo neka gumica koju je zamenio i stavio originalnu i tako mi je sredio klimu. Nedavno sam zamenio i set kvacila sa plivajucim zamajcem. Poslednji problem je ovaj koji se desio sa paljenjem. Kujen je sa 213.000km, a sada ima oko 260.000. Najverovarnije je to prava km jer sam gledao njegovu servisnu knjizicu i nekako mi je logicno da nije puno vozen posle kupovine ona druga dva tourana i da je koriscen za prljave poslove. Cim sam kupio auto, otisao sam kod najboljeg elektronicara u gradu koga znam i on jesa originalnom dijagnostikom video da na dva mesta pamti km i na oba mesta mu je bila ista km sto ukazuje da su ogromne sanse da je km prava itom prilikom mi je rekao da je eger ventil malo zaprljan jer mu je to izbacila dijagnostika. Posto je auto lepo radio, skroz mirno i ravnomerno i u leru, nisam hteo nista da diram kada je eger ventil u pitanju. Mozda sam preterao sa pricom, ali sam hteo da napisem sta se sve desavalo od momenta kupovine.
Drugari, samo da vam javim da je resen problem na mom touranu. Problem je bio u motornom racunaru. Kupio sam polovan motorni racunar sa istim oznakama koje je nosio moj stari za 90e i majstor mi je jos dodatno naplatio 170e, sto ukupno dodje 260e. Sada konacno sve lepo radi. Rekao mi je da je i akumulator los i da on moze da bude uzrok ovih problema za motor im racunarom i preporucuje zamenu akumulatora. Takodje mi je rekao da je stari motorni racunar izbacivao gresku sa zaprljanim egr ventilom igresku sa klapnom gasa,anovi uopste ne prijavljuje te dve greske. Hvala vam puno na odgovorima i pomoci. Veliki pozdrav!
Hvala na savetima. Čim se vratim sa odmora idem kod majstora i javljam sta sam uradio
Hvala, sada ću da pogledam video. Znači to je rešenje za ovaj problem, a nije problem u pumpi
Znači ti smatraše da je problem hot start, a ne pumpa i da treba da se uradi mapa. Nadam se da će moj električar to znati i da neće menjati nešto bez potrebe.
Hvala puno na odgovoru. Provericu danas kleme kako stoje na akumulatoru i da li ima osiguraca kod akumulatora. Ovaj deo oko pumpe ce ipak morati majstor da proveri jer se ja ne razumem i ne znam kako bih mogao da utvrdim sam da li je pumpa crkla ili su losi konektori na pumpi. Od kad sam kupio auto imam problem jer mi kazaljka koja pokazuje nivo goriva u rezervoaru cas radi, a cas ne radi. Elektricar je pre godinu dana video da je prethodni vlasnik sam izgleda hteo nesto da radi oko webasta i navodno je postavljeno neko crevo za webasto, mada je niti znam da li imam webasto, niti znam da li radi, a kada se otvori hauba ima nalepnica za webcasto. Ako je crkla pumpa za gorivo, da li bi ona uopste radila povremeno kao sto radi kod mene ili ne bi uopste radila?
Pozdrav! Imam vw touran 1.9, 77kw, bkc motor, 2005. godiste. Pre 10-ak dana se prvi put desilo da sam imao problem sa paljenjem auta, tj u popodnevnim satima kada sam probao da ga upalim auto samo vergla, ali je cudan zvuk verglanja, kao da se gusi i nece da upali, a primetio sam da kada nece da se upali da tada ne zazuji pumpa prilikom davanja kontakta. Onda vise puta pukusam da upalim i da samo dajem kontakt i da ga iskljucujem i u jednom momentu se cuje zujanje pumpe posle davanja kontakta i tada upali auto. Kada upalim auto, rad motora je ravnomeran i u voznji se lepo ponasa i vuce lepo. Problem sa paljenjem nikad nisam imao u jutarnjim satima pri prvom paljenju. Problem pri paljenju se najcesce desava u toku dana kada pokusam da upalim auto. Imao sam pre par dana kod sebe vcds dijagnostiku i ocitao sam sledece greske i snimio log. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1T (1K0) Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72 VIN: ------------ Mileage: 258050km-160344miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 1010 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 1010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.clb Part No SW: 03G 906 016 CD HW: 028 101 194 5 Component: R4 1,9L EDC G000SG 6246 Revision: 12345678 Serial number: VWZ7Z0E3024218 Coding: 0000072 Shop #: WSC 01324 785 00200 VCID: 67DD0E9B566DDDBEAA-8032 2 Faults Found: 18049 - Please check DTC Memory of A/C Controller P1641 - 000 - - Intermittent Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.24 V Bin. Bits: 00001100 Temperature: 61.2°C (no units): 144.0 19781 - Power Supply Terminal 15 P3325 - 000 - Implausible - Intermittent Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.84 V Bin. Bits: 00001100 Bin. Bits: 0 (no units): 1.0 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA Component: ESP FRONT MK60 0102 Revision: 00H13001 Coding: 0021190 Shop #: WSC 01324 785 00200 VCID: 71E960C368A9130EF4-8024 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1K0 907 044 BE Component: ClimatronicPQ35 090 0808 Shop #: WSC 00000 000 00000 VCID: 6BD572AB4A85F9DECE-803E 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 000 - - 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 D HW: 3C0 937 049 D Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000005166897 Coding: 008B8F210004100000120C000000000000097B075C Shop #: WSC 80093 222 69422 VCID: 2A5BB7AF85FF20D675-807E Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB Component: Wischer VW358 012 0401 Coding: 00065493 Shop #: WSC 80093 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 7 Reset counter: 153 Mileage: 257920 km Time Indication: 0 Freeze Frame: ON Voltage: 12.35 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1T0-909-605.lbl Part No SW: 1T0 909 605 C HW: 1T0 909 605 C Component: 02 AIRBAG VW62 0506 1500 Revision: 09025000 Serial number: 0038BD0G4JWK Coding: 0012338 Shop #: WSC 01324 785 00200 VCID: 356194D35C417F2EE8-8060 2 Faults Found: 01228 - Airbag Cut-Off Switch for Passenger Side (E224) 008 - Implausible Signal - Intermittent - MIL ON 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF Component: Lenksäulenmodul 034 0070 Coding: 0000042 Shop #: WSC 01324 785 00200 VCID: 76E353DF01C7343621-8022 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1T0 920 862 F Component: KOMBIINSTRUMENT VDD 4312 Coding: 0007101 Shop #: WSC 80093 222 69422 VCID: 366393DF41477436E1-8062 3 Faults Found: 00771 - Fuel Level Sensor (G) 003 - Mechanical Failure - Intermittent 00771 - Fuel Level Sensor (G) 010 - Open or Short to Plus - Intermittent 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: 1K0-815-071.clb Part No: 1K0 815 071 P Component: Zuheizer 031 1312 Revision: A Serial number: 09010046 Coding: 0000011 Shop #: WSC 01324 785 00200 VCID: 326BAFCFAD2F6816CD-8066 5 Faults Found: 01415 - Recirculating Pump (V55) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 0 Fault Frequency: 255 Reset counter: 60 Mileage: 254425 km Time Indication: 0 Date: 2000.00.00 Time: 22:54:09 Freeze Frame: OFF Temperature: 27.0°C Temperature: 31.0°C 02085 - Incorrect Control Module Installed 000 - - - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 0 Fault Frequency: 255 Reset counter: 60 Mileage: 254425 km Time Indication: 0 Date: 2000.00.00 Time: 22:54:09 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 52 Reset counter: 187 Mileage: 260917 km Time Indication: 0 Date: 2000.00.00 Time: 28:53:41 01444 - Under-Voltage Shut-Off (Automatic) 000 - - - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 52 Reset counter: 187 Mileage: 260917 km Time Indication: 0 Date: 2000.00.00 Time: 28:53:41 01415 - Recirculating Pump (V55) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 0 Fault Frequency: 255 Reset counter: 60 Mileage: 254425 km Time Indication: 0 Date: 2000.00.00 Time: 22:54:09 Freeze Frame: OFF Temperature: 27.0°C Temperature: 31.0°C ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb Part No SW: 1K0 907 530 F HW: 1K0 907 951 Component: Gateway H10 0120 Revision: H10 Serial number: 2800105B19054C Coding: 3D3F1340078002 Shop #: WSC 01324 785 00200 VCID: 2A5BB7AF85FF20D675-807E 2 Faults Found: 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 156 Mileage: 242033 km Time Indication: 0 Date: 2000.00.00 Time: 15:48:02 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 33 Reset counter: 155 Mileage: 257507 km Time Indication: 0 Date: 2000.00.00 Time: 14:15:26 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No: 1T0 920 862 F Component: IMMO VDD 4312 Shop #: WSC 00000 000 00000 VCID: 366393DF41477436E1-8062 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1T0 959 701 B Component: Tuer-SG 024 2301 Coding: 0000180 Shop #: WSC 01324 785 00200 VCID: 366393DF41477436E1-8062 2 Faults Found: 01552 - Motor for Central Locking; Drivers Door (V56); Lock 012 - Electrical Fault in Circuit - Intermittent 00928 - Locking Module for Central Locking; Front Driver Side (F220) 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K1 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3365AACB5235611EC6-8066 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Mileage: 7480 km Temperature: 27.0°C Voltage: 12.40 V Voltage: 12.20 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb Part No: 1K0 959 433 AK Component: KSG 0401 Coding: 00C802087F2D8405484F016010CC Shop #: WSC 01324 785 00200 VCID: 79F958E330D95B4E4C-802C Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1T0 959 702 B Component: Tuer-SG 024 2301 Coding: 0000180 Shop #: WSC 01324 785 00200 VCID: 377D9EDB464D8D3EFA-8062 2 Faults Found: 00097 - Front Passengers Central Locking (Safe) Motor (V162) 012 - Electrical Fault in Circuit 00929 - Locking Module for Central Locking; Front Passenger Side (F221) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl Part No: 1K0 959 703 B Component: Tuersteuergeraet 06 0214 Coding: 0000048 Shop #: WSC 01324 785 00200 VCID: 2F6DA6BBBE1D45FEA2-807A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl Part No: 1K0 959 704 B Component: Tuersteuergeraet 06 0214 Coding: 0000048 Shop #: WSC 01324 785 00200 VCID: 306FA5C7A3235A06BB-8064 No fault code found. End-------------------------(Elapsed Time: 01:38)--------------------------
