toda81 0 Posted October 6, 2023 Da li mozda neko ima rešenje za ovaj problem? U pitanju je Škoda Karoq 2020. god. 1.6 dizel. Kako UPARITI svetla sa autom? Ovo je log na VCDS: Sunday,01,October,2023,22:13:01:16365 VIN: TMBJG7NU1LJ007008 License Plate: Mileage: 195859km-121701mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NU-SK37 (3Q0) Scan: 01 02 03 05 08 09 10 13 15 17 19 29 2B 36 39 3C 42 44 4B 52 5F 6D 75 A5 BB BC D6 D7 D8 D9 VIN: TMBJG7NU1LJ007008 Mileage: 195859km-121701miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 29-Left Light -- Status: Cannot be reached 0100 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 39-Right Light -- Status: Cannot be reached 0100 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100 D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100 D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100 D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG Component: BCM MQBAB H H40 0312 Serial number: 01001918002178 Dataset Number: V03935307PL 0001 Coding: 060000000000000000000000000000000000000000000000000000000000 Shop #: WSC 00040 790 00030 ASAM Dataset: EV_BCMMQB 020001 ROD: EV_BCMBOSCH_020_VW26.rod VCID: 015F8519318AF4D2005-8054 Rain/Light Recognition Sensor: Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555 Component: G397_RLFSS H06 0002 Serial number: 23245413X81A955555A0 Coding: 80006E Steering Column Switch: Subsystem 2 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A Component: Lenks.Modul H13 0170 Serial number: 0100270620190C301779 3 Faults Found: 541204 - Databus U1123 00 [008] - Received Error Message [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 207 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: Not operated Position lamps: Not operated Automatic high beam assist: operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.8 V Outside temperature: 16.0 �C 568342 - Databus U1123 00 [009] - Received Error Message [LCM rechts - Blinker defekt] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:24 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.8 V Outside temperature: 16.0 �C 568836 - Databus U1121 00 [009] - Missing Message [LWR AFS - Kein Signal/Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:51 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: g�ltiges Funktelegramm Voltage: 12.9 V Outside temperature: 16.0 �C ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 565 920 790 C HW: 565 920 790 C Component: KOMBI 502 4191 Coding: 00A40C1E6F8C0008018C77031001000880200000 Shop #: WSC 80093 222 69422 ASAM Dataset: EV_DashBoardVDDMQBA0 001042 ROD: EV_DashBoardVDDMQBA0_001_VW37.rod VCID: 1E65DE65A0342B2A1D7-804A 1 Fault Found: 16777126 - Function Restricted due to Interrupted Communications U1110 00 [009] - - [BAP_IAA_PSO_0x82 keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:50 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C Component: GW MQB High 521 5388 Serial number: 29061910803182 Dataset Number: V03935300AP 0001 Coding: 030100045F087300231002D2100F00010001070000000000000000000000 Shop #: WSC 00040 790 00031 GVL: 01463C000800060040DC80008000C8000C00C003000200000000000000000000 ASAM Dataset: EV_GatewNF 013026 ROD: EV_GatewNF_VW37.rod VCID: 70B9D0DD0A20ED5AFFB-8024 Generator: Component: 4-01-13-01-04 Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E Component: E221__MFL-PR6 H03 0180 Serial number: 000000000C0511090719 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1051 Serial number: 7588600300190702095E 6 Faults Found: 131714 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x82] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131715 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x83] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131734 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x96] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131735 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x97] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131736 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x98] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On 131737 - No Communications with Undefined Control Module U1126 00 [009] - - [Timeout Knoten 0x99] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 Terminal 30 power supply: 12.8 V Terminal 15: On ------------------------------------------------------------------------------- Address 29: Left Light Cannot be reached ------------------------------------------------------------------------------- Address 39: Right Light Cannot be reached ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E Component: FCM MQB Low 003 0367 Serial number: 24051911603413 Dataset Number: V03935295XK 0001 Coding: 000000040900052200003501190000000000000000000000000000000000 Shop #: WSC 00040 790 00030 ASAM Dataset: EV_MultiModulContiVW48X 003003 ROD: EV_MultiModulContiVW48X_003.rod VCID: 372B2BC12FCE7A62FE1-8062 4 Faults Found: 0037 - Databus for Front Lighting U12EB 00 [009] - Additional Installations Detected [CAN_AFS_multiple_plug_LED_Leimo_identified] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 13706046 - Databus U1123 00 [137] - Received Error Message [LV_Abblendlicht_li_def received error value] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 13706047 - Databus U1123 00 [137] - Received Error Message [LV_Abblendlicht_re_def received error value] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 0032 - Headlight C107E 54 [137] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 167 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:48 ------------------------------------------------------------------------------- Address BB: Door Rear Drv Cannot be reached ------------------------------------------------------------------------------- Address BC: Door Rear Pass Cannot be reached ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A Component: LED1L H07 0009 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 025D8A15348CEFCA19F-8056 2 Faults Found: 0338 - Databus U1121 00 [175] - Missing Message [can message LCM_Soll_Fkt missing] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 0773 - Supply Voltage for Low-Beam C11FD 13 [174] - Open Circuit MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A Component: LED1R H07 0009 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 025D8A15348CEFCA19F-8056 2 Faults Found: 0338 - Databus U1121 00 [175] - Missing Message [can message LCM_Soll_Fkt missing] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:09:49 0773 - Supply Voltage for Low-Beam C11FD 13 [174] - Open Circuit MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 0 Mileage: 195859 km Date: 2023.10.01 Time: 22:10:17 ------------------------------------------------------------------------------- Address D8: LED HeadL. Pwr Left Cannot be reached ------------------------------------------------------------------------------- Address D9: LED HeadL. Pwr Right Cannot be reached End----------(Elapsed Time: 01:56, VBatt start/end: 13.0V/13.0V)----------- Share this post Link to post Share on other sites
projektilski 277 Posted October 9, 2023 Sto znaci upariti svijetla? Daj vise informacija sto je bilo, sto si radio, koje je novo stanje... Share this post Link to post Share on other sites
toda81 0 Posted October 10, 2023 Auto ne vidi farove i zmigavce. Odjavljeni sa auta. Treba module farova da doda na gataway Share this post Link to post Share on other sites
