toda81
Škoda Karoq 2020. god. 1.6 dizel - uparivanje svetala
Da li mozda neko ima rešenje za ovaj problem? U pitanju je Škoda Karoq 2020. god. 1.6 dizel. Kako UPARITI svetla sa autom? Ovo je log na VCDS:
Sunday,01,October,2023,22:13:01:16365
VIN: TMBJG7NU1LJ007008   License Plate:
Mileage: 195859km-121701mi   Repair Order:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 29 2B 36 39 3C 42 44 4B 52
          5F 6D 75 A5 BB BC D6 D7 D8 D9
VIN: TMBJG7NU1LJ007008   Mileage: 195859km-121701miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
29-Left Light -- Status: Cannot be reached 0100
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: Cannot be reached 0100
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 01001918002178 Dataset Number: V03935307PL 0001
   Coding: 060000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 00040 790 00030
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW26.rod
   VCID: 015F8519318AF4D2005-8054
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06  0002
   Serial number: 23245413X81A955555A0
   Coding: 80006E
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 AG    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100270620190C301779
3 Faults Found:
541204 - Databus
          U1123 00 [008] - Received Error Message
          [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:10:17
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Automatic high beam assist: operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: g�ltiges Funktelegramm
                    Voltage: 12.8 V
                    Outside temperature: 16.0 �C
568342 - Databus
          U1123 00 [009] - Received Error Message
          [LCM rechts - Blinker defekt]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:10:24
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Automatic high beam assist: Not operated
                    Voltage: 12.8 V
568836 - Databus
          U1121 00 [009] - Missing Message
          [LWR AFS - Kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:51
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.9 V
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 565 920 790 C    HW: 565 920 790 C
   Component: KOMBI         502 4191
   Coding: 00A40C1E6F8C0008018C77031001000880200000
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1E65DE65A0342B2A1D7-804A
1 Fault Found:
16777126 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_IAA_PSO_0x82 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:50
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 29061910803182 Dataset Number: V03935300AP 0001
   Coding: 030100045F087300231002D2100F00010001070000000000000000000000
   Shop #: WSC 00040 790 00031
   GVL: 01463C000800060040DC80008000C8000C00C003000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D0DD0A20ED5AFFB-8024
   Generator:
   Component: 4-01-13-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000C0511090719
Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1051
   Serial number: 7588600300190702095E
6 Faults Found:
131714 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x82]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 30 power supply: 12.8 V
                    Terminal 15: On
131715 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x83]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 15: On
131734 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x96]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 15: On
131735 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x97]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 15: On
131736 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x98]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 15: On
131737 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x99]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
                    Terminal 15: On
Address 29: Left Light
Cannot be reached
Address 39: Right Light
Cannot be reached
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 24051911603413 Dataset Number: V03935295XK 0001
   Coding: 000000040900052200003501190000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372B2BC12FCE7A62FE1-8062
4 Faults Found:
0037 - Databus for Front Lighting
          U12EB 00 [009] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LED_Leimo_identified]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:48
13706046 - Databus
          U1123 00 [137] - Received Error Message
          [LV_Abblendlicht_li_def received error value]
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:48
13706047 - Databus
          [LV_Abblendlicht_re_def received error value]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:48
0032 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:48
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025D8A15348CEFCA19F-8056
2 Faults Found:
0338 - Databus
          U1121 00 [175] - Missing Message
          [can message LCM_Soll_Fkt missing]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
0773 - Supply Voltage for Low-Beam
          C11FD 13 [174] - Open Circuit
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:10:17
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
2 Faults Found:
0338 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:09:49
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 195859 km
                    Date: 2023.10.01
                    Time: 22:10:17
Address D8: LED HeadL. Pwr Left
Cannot be reached
Address D9: LED HeadL. Pwr Right
Cannot be reached
End----------(Elapsed Time: 01:56, VBatt start/end: 13.0V/13.0V)-----------
Sto znaci upariti svijetla? Daj vise informacija sto je bilo, sto si radio, koje je novo stanje...
Auto ne vidi farove i zmigavce. Odjavljeni sa auta. Treba module farova da doda na gataway
