nightwalker93 5 Posted June 23 Pozdrav, Golf 7 u pitanju, klima i sve radi dobro ali ne puše mi nikakav zrak na srednjim ventilacijama iznad radija, vcds izbacuje grešku za flapne neke i gledo sam po forumu ima ih više komada pa sad nezz koja je 4 Faults Found: 328964 - Motor for Front Air Distribution Flap B1091 71 [009] - Actuator stuck Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Reset counter: 68 Mileage: 141129 km Date: 2024.04.20 Time: 18:43:26 Voltage terminal 30: 12.5 V Outside air temperature: 13.5 °C Interior temperature: 25.1 °C Front air distribution flap: actual value: 232 Front air distribution flap: actual value: 100.0 % Front air distribution flap: specified value: 126 328965 - Motor for Front Air Distribution Flap B1091 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 217 Mileage: 141096 km Date: 2024.04.19 Time: 11:30:19 Voltage terminal 30: 11.6 V Outside air temperature: 16.5 °C Interior temperature: 32.1 °C Front air distribution flap: actual value: 232 Front air distribution flap: actual value: 100.0 % Front air distribution flap: specified value: 15 329476 - Motor for Fresh Air / Recirculated Air Flap B108B 71 [009] - Actuator stuck Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 219 Mileage: 141129 km Date: 2024.04.20 Time: 18:43:26 Voltage terminal 30: 12.5 V Outside air temperature: 13.5 °C Interior temperature: 25.1 °C Actual value for fresh air/recirculation air flow flap: 206 Actual value for fresh air/recirculation air flow flap: 100.0 % Specified value for fresh air/recirc air flow flap: 96 329477 - Motor for Fresh Air / Recirculated Air Flap B108B 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 217 Mileage: 141096 km Date: 2024.04.19 Time: 11:30:18 Voltage terminal 30: 11.6 V Outside air temperature: 16.5 °C Interior temperature: 32.1 °C Actual value for fresh air/recirculation air flow flap: 206 Actual value for fresh air/recirculation air flow flap: 100.0 % Specified value for fresh air/recirc air flow flap: 80 Share this post Link to post Share on other sites
