Guest General Posted May 5, 2009 (edited) kupio sam mk5 2.0 tdi prije mjesec dana i odlucio sam malo poraditi na njemu. sad je trenutno plavo nebeske boje a bit ce biserno bijele... pa pratite napredak... evo malo slika... Edited May 26, 2009 by pikzibner Share this post Link to post Share on other sites
Guest General Posted May 5, 2009 Komentari: http://www.vwclubcroatia.com/forums/index....showtopic=25352 Share this post Link to post Share on other sites
Guest General Posted May 5, 2009 a izgledat ce ovako samo bez tih felgi... Share this post Link to post Share on other sites
Guest General Posted May 19, 2009 EVO MALO SLIKA KAD JE RASTAVLJEN Share this post Link to post Share on other sites
Guest General Posted May 19, 2009 STIGAO JE OETTINGEROV BRANIK Share this post Link to post Share on other sites
Guest General Posted May 19, 2009 SAD JE U FAZI SASTAVLJANJA Share this post Link to post Share on other sites
Guest General Posted May 22, 2009 auto je gotov i evo malo slika, stavljeni su zadnji crni štopovi, zatamljena su stakla, obojana kljesta itd... Share this post Link to post Share on other sites
Guest General Posted May 22, 2009 (edited) evo ih... motor za koji tjedan ide na 170hp, dolaze mi prednji farovi sa lecom... pozz Edited May 25, 2009 by pikzibner Share this post Link to post Share on other sites
Guest General Posted May 26, 2009 (edited) evo stigle su i felge... Edited May 26, 2009 by pikzibner Share this post Link to post Share on other sites
Guest General Posted May 27, 2009 evo i papucica... Share this post Link to post Share on other sites
Guest General Posted August 11, 2009 evo malo da vam se javim, posto me nije bilo jedno vrijeme, imali smo malih poteskoca... Male promjene na auto: Auto je chipan sad izbacuje 170hp kod thperformanc u zg, njima svaka cast zamjenjene su zadnje lampe sad su od r32 stavljeni su crni farovi sa xenonama zadnji branik isto montiran ispuh jos neznam gdje cu ga raditi pa ako ima neki predlog neka se izjasni slike stizu Share this post Link to post Share on other sites
Guest General Posted August 11, 2009 Komentari: http://www.vwclubcroatia.com/forums/index....showtopic=25352 Share this post Link to post Share on other sites
Guest General Posted August 14, 2009 evo malo slika... Share this post Link to post Share on other sites
