Memphis 45 Posted August 8, 2021 pa jel probao kako ti radi vakum ventil? Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 8, 2021 Sve ispravno,svi ventili,sve zivo sam izmjenjao, osim map senzora, nema nikakvih greski na vcds-u Share this post Link to post Share on other sites
mur3633 269 Posted August 8, 2021 Stavi fabričku mapu motora pa probaj 1 Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 9, 2021 zamjenucu i taj map senzor kad sam sve zamjenuo,pa za dalje cemo vidjeti Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 13, 2021 Otkrio sam da vakum crijevo od n75 ventila do ventila na turbu su 3mm a fabricki su isla valjdao od 4mm,da li moze da dodje do gubitka snage zbog manjeg promjera vakum crijeva Share this post Link to post Share on other sites
Memphis 45 Posted August 13, 2021 ne, to crijevo se s vremenom suzi. Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 14, 2021 Vecu glupost nisam cuo odavno 1 Share this post Link to post Share on other sites
mur3633 269 Posted August 14, 2021 Otkrio sam da vakum crijevo od n75 ventila do ventila na turbu su 3mm a fabricki su isla valjdao od 4mm,da li moze da dodje do gubitka snage zbog manjeg promjera vakum crijevaNe možeNije to neka razlika 1 Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 14, 2021 Hvala i ja tako mislim Share this post Link to post Share on other sites
Memphis 45 Posted August 15, 2021 On 8/14/2021 at 3:02 PM, GTI-VR6-R32 said: Vecu glupost nisam cuo odavno Pa naravno da nisi kad nemaš pojma. A kamoli kad bi znao kaj je to vakum i kako dela. 1 Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 17, 2021 (edited) Da cujem kako se suzi crijevo Edited August 17, 2021 by GTI-VR6-R32 Share this post Link to post Share on other sites
luka93 26 Posted August 17, 2021 Da cujem kako se suzi crijevoVakuum? Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 17, 2021 Pa mozda, ali ne vjerujem Share this post Link to post Share on other sites
GTI-VR6-R32 38 Posted August 25, 2021 (edited) Update,ni poslije izmjene map senzora ima neke sitne razlike ali nije to to,sad kad startujem auto ujutru prvi put,turbina se uopste ne cuje nikako,nema ono njeno zvizdanje,kad krenem da vozim nema snage do 2000 rpm nikako,ko sdi da vozim ma nista 1-2 brzina trom skroz,potopis gas na 1800 rpm i nista ne vuce,tek nakon nekih 1km voznje turbo se sam upali,krene da zvizdi i auto ide ko metak, i kad poslije voznje ostavim ga pola sata ugasen i ponovo krenem isto se dogadja to, geometrija turba ciscenje,sva crijeva vakum zamjenjena,sva crijeva od interkulera do turba pregledana,n75 zamjenjen,maf,map. Edited August 25, 2021 by GTI-VR6-R32 Share this post Link to post Share on other sites
