Marco Polo 0 Posted January 10, 2010 Da li postoji neka željezna zaštita za VW Polo 9N ili 9N3? I ako znate kataloški broj?? Share this post Link to post Share on other sites
vwgolf3 0 Posted January 11, 2010 ...također za audi A4... volio bi znati cijenu pa ako nije skupo da nemoram više strahovat za karter i ostale djelove dolje... Share this post Link to post Share on other sites
vr-turbo 0 Posted January 11, 2010 Mislim da sam vidio tu na forumu da za g4 postoji..za pola i audi-a neznam Share this post Link to post Share on other sites
tihca 0 Posted January 12, 2010 (edited) Gdje???? u servisu,bilo je negdje na forumu a i kataloški broj kolko se sjećam,al nije jeftino po sjećanju... Zna netko za normalnu zaštitu ispod motora za Pola 9N,osim u ovlaštenom servisu(preskupo) i Velasu(ne postoji).... Edited January 12, 2010 by tihca Share this post Link to post Share on other sites
joke 0 Posted January 12, 2010 ...također za audi A4... volio bi znati cijenu pa ako nije skupo da nemoram više strahovat za karter i ostale djelove dolje... Nekih 1600kn ja mislim da je bila kad sam uzimo za passata.... Share this post Link to post Share on other sites
tihca 0 Posted January 29, 2010 jel zna netko ako paše na pola sdi-a 03 god. zaštita od ibize SDI ili fabije SDI,ili od pola benzinca...gledao sam u ETKI i nisam našao nikakvu razliku Share this post Link to post Share on other sites
jady 5 Posted January 29, 2010 polo 9n sound deadener underbody lining / sound deadener (1) 6Q0825237R sound deadener / otto engine: 60KW (1) 6Q0825237T sound deadener / adapt with workshop equipment / otto engine: 74-91KW 1 6Q0825237P sound deadener / for 5 speed manual transmiss. / diesel eng. 2 N 90533301 clip C7,9X9,4X20 / diesel eng. 3 N 0154391 snap nut ST4,8X16,5X13 / 4 N 10327101 speed nut ST4,8 / diesel eng.; otto engine: 74KW>> 5 N 90775001 torx socket head panel screw / underbody lining / 4,8X16 8 6Q0825201D underbody lining left front / (8) 6Q0825202F underbody lining / adapt with workshop equipment right front rework / otto engine/ diesel eng. diesel eng.: TDI 9 N 90335004 A4 B5 cover for jointed shaft / cover for engine compartment / 1 8D0863821S sound deadener / otto engine 1 8D0863821Q sound deadener / diesel eng. - 8D0863821D sound deadener / for models with drive system protective plates / F >> 8D-V-200 000* left / - 8D0863821E sound deadener / for models with drive system protective plates / F >> 8D-V-200 000* right / (1) 8D0863821P sound deadener / for models with drive system protective plates / F 8D-V-200 001>>* heavy-duty / - N 0200241 plug A10X1 / - N 90570601 allen key head bolt (combi) M10X24Z1 / 2 8D0863822 sound deadener / diesel eng. 3 8D0805960 snap nut / 4 8D0805121 grip pin 6X18MM silver / 4A 8D0805121 grip pin 6X18MM silver / (4A) 8D0805121B grip pin 6X20MM black / diesel eng. 5 4A0805121A grip pin / 6 4A0805137A lock washer / 7 4A0805163 clip / (8) 8D0807513 spoiler / damping pan left / (8) 8D0807514 spoiler / damping pan right / (9) N 0385491 split rivet 8X12 / 10 8D0863843 retainer / 11 4A0805137 rubber washer 25MM / 12 N 90168602 snap nut M6X16X24 / 13 N 0901483 hexagon head bolt (combi) M6X15Z2 / 16 8D0805960 snap nut / 17 4A0805137 rubber washer 25MM / 18 8D0805121 grip pin 6X18MM / 19 8D1864309 cover for engine compartment left lhd / (19) 8D2864309 cover for engine compartment left rhd / (19) 8D1864310 cover for engine compartment right lhd / (19) 8D2864310 cover for engine compartment right rhd / 20 171201969 hexagon nut, shouldered 5 / 21 823863203 clip / 823863203 01C satin black / 22 8D0863187 cover for jointed shaft left / (22) 8D0863188 cover for jointed shaft right / 23 N 90821401 expanding nut D4,8 / 24 N 90775001 sve iz e.t.ke izvadjeno.... Share this post Link to post Share on other sites
tihca 0 Posted January 30, 2010 to je to jady,i ja sam to našao,jedino što kužim da nejde od benzinca na dizela... tdi 101,tdi 75,sdi 64ks imaju istu zaštitu?najviše me zanima ako se može od ibize stavit,s time da ja kupim onaj dio koji ide na branik ispod kilera Share this post Link to post Share on other sites
puks 0 Posted January 30, 2010 To je to Jady ali plasticne zastite Za G IV postoji metalna koja dolazi sa dva nosača koja se sarafe direkt na krakove sasije tako da ak se udari s njom bude jako cvrsta ima je moj prijatelj na svojoj cetvorki (G IV - G V GTi look) samo sto neznam org brojeve i cijenu kupljeno je u Porscheu na Jankomiru Share this post Link to post Share on other sites
jady 5 Posted January 30, 2010 znam da su to plasticne zvucne izolacije i da za G4 i limena zastita ima.al moglo bi se i napravit od inoxa ili nesto slicno...samo je stvar cijene Share this post Link to post Share on other sites
tihca 0 Posted January 30, 2010 puks ja sam pitao za plastičnu Share this post Link to post Share on other sites
Jura31 0 Posted January 30, 2010 ma tog kod ljudi koji rade sa djelovima po 100kn, ja sam nasao deckima u okolici za golfa, ibizu, pola, passata. neki kad dodu kod mene ne zele vise to na autu, a ja ih ubjedujem da to ne skidaju (kreteni)ali meni dobro dode jer se to uvijek moze prodati. Share this post Link to post Share on other sites
tihca 0 Posted January 30, 2010 da je tako lako naći nebi ja pitao... Share this post Link to post Share on other sites
Vec 1 Posted February 7, 2010 kol'ko kosta plasticna za MK4? ... na audi forumu sam procit'o da kod ovlastenog za A3 kosta 300kuna? Share this post Link to post Share on other sites
tihca 0 Posted February 7, 2010 Vec nije ziher,da je tak jeftino već bi ja kupio kod ovlaštenog Share this post Link to post Share on other sites
Vec 1 Posted February 7, 2010 Vec nije ziher,da je tak jeftino već bi ja kupio kod ovlaštenog pa da,zato pitam,tamo sam isto stavio oglas da trazim i kaze mi tip pogledaj kod ovlastenog, za A3 kod Zubaka je oko 300 kn, mislim da je tocno 290kn. meni je danas otpala ta plastika i nemoze se vise nasarafit gore Share this post Link to post Share on other sites
jady 5 Posted February 7, 2010 bocne plastike sam platio po 200 i nesto kuna...srednji je sigurno dosta skuplji... Share this post Link to post Share on other sites
Vec 1 Posted February 7, 2010 (edited) meni ovo treba od zapinjanja je sva popucala na rubovima i vise se nema di sarafit... polovno ce se JAKO tesko nac' ... a u ovlasteni bi zadnje isao ... jbte... Edited February 7, 2010 by VecTDI Share this post Link to post Share on other sites
