7 7
TheFog
Slike: Corrado
koja je ovo boja na ovom zadnjem raddu sta je nizde posta,
Čini mi se da je to ista boja kao i moj.
Neznam koji je kod.
Jaaaako lijep Corrado.
Ovakve felge tražim za svog.
Naravno nakon ladera.
Pa imao ti je Kremni g-lader sa motorom za super pare,što nisi uzeo.
Ovdje je fora u gumi , a ne felgi
Guma je 215/35-17 koja ima istu visinu kao 195/45-16 ;-)
Znači 17'' , visina auta kao da je na 16'' , puno je niža od 205/40-17...
Računao i kombinirao ja sinoć sebi pa našao ove slike :grrr
Eto Pero sad i ti stavi ovakve felgice na tvog Coranda.
Bi ja , ali ih nema nigdje na prodaju...
Te felge su 8.5 široke
Teško je nać takve da su uže. :angry:
Čekam da mi otvori lader, pa se nadam da će ić meni doma
Sorry na OT
Ovo je tako istina i tu se poznaju junaci :)
Rules for buying Corrados:
1. Timing chain recently done/ charger rebuild recently done (with proof) or the car is instantly worth $800- $1000 less. “G60” cars without the actual charger also apply to this rule.
2. The car is worth less than the sum of its parts, period.
3. In spite of rule 2, the car is not worth a fortune in parts, so sales pitches like “the engine alone is worth that much” are likely false.
4. “That grinding when you shift is normal for these cars” may unfortunately be true, but you should still run away from that particular car. This goes for pretty much any claim that states "that is just a normal Corrado issue." Also watch out for "you just don't know how to drive it correctly, there is a special way you have to drive it."
5. Expect to spend at least the purchase price of the car, averaging $2000, on repairs, maintenance, and upgrades within 1 year. Expect a similar amount every 2 to 3 years following the first year of ownership [see rules 6 and 7 for more details].
6. [Rule 5 assumes] You are mechanically inclined and are willing to make (repairing) this car one of your primary free time activities [if this does not apply to you, see rule 7].
7. Never buy a Corrado unless you have a mechanic whom you trust implicitly and specifically attests to having first-hand experience repairing Corrados. [if you are to use said mechanic, double the estimate in rule 5].
8. Do not buy one of these cars as a primary daily driver.
9. Do not buy one of these cars from a kid or someone who has not kept it in top shape. If you do, you will probably be purchasing what are called “molested Corrados” in the Corrado circle and are likely to have major defects that were ignored in favor of tacky cosmetic or questionable performance upgrades. Don’t be blinded by how “cool” the car is or how many “upgrades” it has and mind these rules. It will seem much less “cool” if it ends up on jack stands for 6 months in your driveway or you end up having to take out a loan to pay your mechanic. [since creating this rule, it has been mentioned that there are "kids" in existance who have not destroyed Corrados for the buyer, no personal insult was intended]
10. Research these cars and their stereotypical problems on sites like http://www.corrado-club.ca/forum/ or Vwvortex. You should go into your purchase being an amateur expert for fear of being a professional-grade fool.
Rules for owning a Corrado
1. Never think about how much you are spending, have spent, or will spend on these cars. If you think about it like an accountant, you will want to sell it. If you cannot follow this rule, sell the car now.
2. Get a Bentley manual and actually use it. So many times, the simplest problem can be avoided by browsing a section in the Bentley. In addition, cruise sites like VWvortex for assistance from other experienced Corrado owners/ amateur mechanics/ experts.
3. Fix the things that are wrong with the car, then the things that will be wrong with it soon. After driving a while in this state, then start with performance modifications.
4. Beer, coffee, and junk food will be your friends who will give you comfort while owning/ working on Corrado(s). Keep a stash handy (especially of alcohol) for those times when you are waiting for the tow truck or are regretting your Corrado purchase.
5. These are not Hondas, don’t make them look like they are and don't expect to drive (and neglect) them as if they were Hondas.
6. Carry jumper cables, duct tape, and basic tools. You will need them.
7. (For G60) replace the cog belt every 1-2 years. Replace with wide or superwide for longevity.
The following rules apply only to those who do their own work on their Corrado
7. Blame everything on the PO or just the entire country of Germany
8. Buy gloves, possibly use them.
9. Replace the stupid round hex key bolts.
10. Never use the factory jack without fully acknowledging that your peril is more than possible.
11. Get AAA
Top things to replace or upgrade (remember, after car is already running correctly), G60 biased, no particular order.
1. Motor mounts/ transmission mounts
2. Supercharger rebuild/ upgraded pulley, belt, boring, ISV reroute, chip
3. Install VR6 strut bearings, hybrid control arm bushings
4. Euro headlights, relayed
5. Oil Cooler or lower temp fan switch and thermostat
6. Grounding kit, replace battery cables, alternator wire, adjustable voltage regulator
7. Replace motorized seatbelts with euro/ Canadian belts
8. Skid plate
9. Boost gauge, Oil pressure gauge, volt meter (for added style points, put it in the cubby or DIN).
10. Coilovers or a sport spring/ shock combo (Bilstein/ Koni, cup kit, etc.)
11. (If you can afford it) LSD (limited slip differential) or new synthetic Redline or Amsoil gear lube
12. Passat moonroof
13. Replace AKTIV stereo system with standard aftermarket system
14. Girling 60 calipers
15. Clear front turn signals
To si stavio da mi skratiš muke oko felgi ? :palci
Za sve one kojima mehaničari slažu aute , a htjeli bi Corrada , nažalost , istina...
Ne straši ljude :lol2
Sad niko neče kupit od mene onog zelenog corrado G-a kad vidi sve ovo :lol:
I zbog zamazanih siceva :P
:wow:wow:wow:wow
photoshop ili stvarno....j3benoooo izgleda,,,al nekako nisko za vr-a zato mi sumnjivo..a mozda se varam
:wow:wow:wow:wow
znas znanje i gotovo, karter je u visni tj. u nizini prednje duboke ralice, katalizator mrvicu njze, vilice takodjer mrvicu nize od kartera, tako da ova malena ralice
ne prolazi nikako....
al sta jest jest izgleda ajme dobro :respekt
Nažalost , ovo je iz photoshpo threada... Ali je predobro.
Možda budemo imali ovakav Cortradao kada stavimo elektromotor un unutra , onda nema kartera :D
jos meni cudno kako su likovi glavati u autu....i pomislim na PS ali reko ma sta ja znam....kad ono da
ovaj me zajebo....ima 9.5 J felge a na njima 195-45 :grrr
guma tu izgleda baloonka...
7 7
