smmania
P:sat suunto vector
U KOJEM SVIJETU I NA KOJEM FORUMU TREBA POSTAVIT PRAVILA PA DA IH VI PRIMJETITE I PROUČITE PA DA SHVATITE DA JE BUMP DOZVOLJEN SAMO I JEDINO SVAKIH 14 DANA A ZA SVE OSTALO,ZNAČI U OVOM SLUČAJU PROMJENE CIJENE ILI DODAVANJE SLIKA,SE KORISTI EDIT OGLASA
HVALA NA RAZUMIJEVANJU
LP
prodajem svoj sat
nosen 2 mjeseca
od opcija ima
Technical specifications
Expand all
Expand all
Collapse all
Collapse all
Print
Altimeter
Altitude alarm
Vertical speed
Temperature compensation
Resolution 5 m
Recording intervals 20s, 60s, 10min, 60min
Automatic 24-hour memory
Altitude range -500m - 9000m/-1600ft - 29500ft
Difference measurement
History memory
Logbook function
Chronograph
Countdown timer
Stopwatch
Max number of split times in memory 2
Compass
North-South indicator North-South indicator
Heading in degrees
Declination setting
Cardinal directions
Bearing tracking
Compass with bubble level
Other
Weight 54 g
Operating temperature -20°C - +60°C/-5°F - +140°F
User replaceable straps
Water resistance 30m/100ft
Storage temperature -30°C - +60°C/-22°F - +140°F
Selectable metric/imperial units
Backlight type Electro-luminescent Display
Power
Low battery warning
User replaceable battery
Special
Rotating bezel
Watch
12/24h
Calendar clock
Daily alarms 3
Weather
Absolute barometric pressure
Temperature resolution 1°C/1°F
Weather memory 4 days
Trend indicator
Temperature range -20°C - +60°C/-5°F - +140°F
Temperature
Sea level pressure
Barometer resolution 0,05 inHg/1 mbar
Barometer range 8,9 -32,4 inHg/300-1100 mbar
više mozete pogledat tu
http://www.suunto.com/en/products/Outdoor_...or-black/#Specs
da se razumijemo to nije sat sa standa cijena u hrvatskoj je 2500 kn a ja svoj prodajem za 750 nije fix kn jer sam ostao bez posla a novci su mi potrebni
do subote 500 kn peljam u rijeku ako ko hoce !!! samo do subote
500 kn
Edited by rrocado
