smmania 0 Posted March 3, 2011 (edited) U KOJEM SVIJETU I NA KOJEM FORUMU TREBA POSTAVIT PRAVILA PA DA IH VI PRIMJETITE I PROUČITE PA DA SHVATITE DA JE BUMP DOZVOLJEN SAMO I JEDINO SVAKIH 14 DANA A ZA SVE OSTALO,ZNAČI U OVOM SLUČAJU PROMJENE CIJENE ILI DODAVANJE SLIKA,SE KORISTI EDIT OGLASA HVALA NA RAZUMIJEVANJU LP prodajem svoj sat nosen 2 mjeseca od opcija ima Technical specifications Expand all Expand all Collapse all Collapse all Print Altimeter Altitude alarm ✓ Vertical speed ✓ Temperature compensation ✓ Resolution 5 m Recording intervals 20s, 60s, 10min, 60min Automatic 24-hour memory ✓ Altitude range -500m - 9000m/-1600ft - 29500ft ✓ Difference measurement ✓ History memory ✓ Logbook function ✓ Chronograph Countdown timer ✓ Stopwatch ✓ Max number of split times in memory 2 Compass North-South indicator North-South indicator Heading in degrees ✓ Declination setting ✓ Cardinal directions ✓ Bearing tracking ✓ Compass with bubble level ✓ Other Weight 54 g Operating temperature -20°C - +60°C/-5°F - +140°F User replaceable straps ✓ Water resistance 30m/100ft Storage temperature -30°C - +60°C/-22°F - +140°F Selectable metric/imperial units ✓ Backlight type Electro-luminescent Display Power Low battery warning ✓ User replaceable battery ✓ Special Rotating bezel ✓ Watch 12/24h ✓ Calendar clock ✓ Daily alarms 3 Weather Absolute barometric pressure ✓ Temperature resolution 1°C/1°F Weather memory 4 days Trend indicator ✓ Temperature range -20°C - +60°C/-5°F - +140°F Temperature ✓ Sea level pressure ✓ Difference measurement ✓ Barometer resolution 0,05 inHg/1 mbar ✓ Barometer range 8,9 -32,4 inHg/300-1100 mbar više mozete pogledat tu http://www.suunto.com/en/products/Outdoor_...or-black/#Specs da se razumijemo to nije sat sa standa cijena u hrvatskoj je 2500 kn a ja svoj prodajem za 750 nije fix kn jer sam ostao bez posla a novci su mi potrebni do subote 500 kn peljam u rijeku ako ko hoce !!! samo do subote 500 kn Edited March 9, 2011 by rrocado Share this post Link to post Share on other sites
