Leic 2 Posted September 15, 2011 (edited) Dakle zanima me može li se još kako riješiti pražnjenje akumulatora osim zamjene Gatewaya. Jel netko probao, možda samo treba otpojiti neku žicu ili nešto, nešto jednostavnije ili jeftinije. Možda da se ugradi neki otpornik ili nešto. Nemogu nigdje nac Gateway a novi je preskup Edited September 15, 2011 by Leic Share this post Link to post Share on other sites
Dario_7R 34 Posted September 15, 2011 imas ih po 50 eura na Ebay Share this post Link to post Share on other sites
Leic 2 Posted September 16, 2011 Hvala, znam to, ali mene zanima kako to drukcije rijesiti da se on ne mijenja. Mora postojat neki drugi nacin Share this post Link to post Share on other sites
audicabrio 0 Posted September 16, 2011 mozda bi tihi to mogao srediti... 0989008344 Share this post Link to post Share on other sites
Dario_7R 34 Posted September 16, 2011 Leic said: Hvala, znam to, ali mene zanima kako to drukcije rijesiti da se on ne mijenja. Mora postojat neki drugi nacin mozes ga DGat soft. ovdje ti je software ,50% su ti sanse,ako opet vuce struju onda je prestar CAN Quote http://www.megaupload.com/?d=VD5REKW1 Share this post Link to post Share on other sites
MarioIV 11 Posted September 21, 2011 (edited) evo ja sam ovo nasao ako tko kuzi sta treba i gdje treba kodirati Module 19 - CAN Gateway puis 07 Coding puis décocher "Radio Analogic" EDIT: to radi 100% samo radio treba svaki put paliti rucno na tipku prilikom paljenja auta Edited September 21, 2011 by MarioIV Share this post Link to post Share on other sites
Leic 2 Posted September 24, 2011 Jesi probao sa RCD 510, jer se navodno za RNS može riješiti a za RCD ne, sad neznam dali je to to Share this post Link to post Share on other sites
MarioIV 11 Posted September 24, 2011 to sa softwerom je samo za rns ovo sto sam ja napisao radi sigurno Share this post Link to post Share on other sites
Leic 2 Posted September 30, 2011 (edited) Nasao sam ja. Znaci treba ic na module 19-CAN Gateway, onda na Coding 07 i na Long coding helper i tu ima Radio analog i to sam iskljucio, sad cemo vidjet kroz par dana dali to vrijedi. I da, radio treba palit i gasit svaki put na tipku znaci ne pali i gasi se na kljuc. Evo i tog ekrana Jos jedino neznam za ovo Radio digital dali bi to pomoglo, tu se radio pali i gasi sam, znaci na kljuc to sam isprobao, samo neznam dali tu izvuce aku. morat cu to probat kad vidim dali ovako radi Edited September 30, 2011 by Leic Share this post Link to post Share on other sites
MarioIV 11 Posted September 30, 2011 tak ti radi 100% ajd probaj to radio digital Share this post Link to post Share on other sites
marko.p 0 Posted September 30, 2011 dogodilo se to da nisu svijetle tipke po danu a sad navečer svijetle Jel moguće da ima neki senzor? Share this post Link to post Share on other sites
himzo 0 Posted September 30, 2011 marko.p said: dogodilo se to da nisu svijetle tipke po danu a sad navečer svijetle Jel moguće da ima neki senzor? To ti je prednost u odnosu na costum fit uređaje. Čita sa CAN busa senzor svjetla/tame, RNS i brzinu (navigacija radi u tunelu), prikaz klime, stišavanje radia kada se pale park senzori ili ako imaš bluetooth onda i na poziv. Share this post Link to post Share on other sites
marko.p 0 Posted September 30, 2011 himzo said: To ti je prednost u odnosu na costum fit uređaje. Čita sa CAN busa senzor svjetla/tame, RNS i brzinu (navigacija radi u tunelu), prikaz klime, stišavanje radia kada se pale park senzori ili ako imaš bluetooth onda i na poziv. ali nema auto senzor svjetlosti Share this post Link to post Share on other sites
Leic 2 Posted October 1, 2011 tocno tako, auto nema senzor, a dogadja se to da jednom svijetle tipke drugi put ne. Na radio digital svijetli normalno sad cemo vidjet dali tu prazni aku Share this post Link to post Share on other sites
lala30 0 Posted October 2, 2011 Leic said: tocno tako, auto nema senzor, a dogadja se to da jednom svijetle tipke drugi put ne. Na radio digital svijetli normalno sad cemo vidjet dali tu prazni aku tipke svijtle kada je upaljena pozicija ili glavno svijetlo , ako tako neradi onda nešto neštima sa can-bus Share this post Link to post Share on other sites
MarioIV 11 Posted October 26, 2011 sta je bilo sa ovim na kraju? Share this post Link to post Share on other sites
acs 0 Posted October 26, 2011 (edited) izvinjavam se zbog velicine slike ali ovo je najsvezije nezvanicno rjesenje! Edited October 26, 2011 by acs Share this post Link to post Share on other sites
Leic 2 Posted October 27, 2011 Popio mi je krv, deset puta sam ga stavljao i vadio i na kraju prodao u golfa VI. Ali ako netko bude potvrdio da je ovo 101% sigurno kupujem ga opet. Ono sa radio analog mozete zaboravit jel tipke ne svijetle, pa jednom svijetle pa opet ne i tako, vjerojatno zajebava can-bus Share this post Link to post Share on other sites
Dario_7R 34 Posted October 27, 2011 sorry ali skrt si bio za 50eura za CAN bus ,gubio si vrijeme s glupostima i ove razno razne kemije Share this post Link to post Share on other sites
Leic 2 Posted October 27, 2011 Da sam bio škrt nebi ni kupio taj auto ni taj radio nego neki fiat, a da sam nasao za 50eur kupio bi ga i ako ovo funkcionira kupit cu ponovo. Ja sam samo pitao dali postoji drugo rjesenje tako da... Share this post Link to post Share on other sites
Dario_7R 34 Posted October 27, 2011 ne postoji drugo rješenje Share this post Link to post Share on other sites
Lycan 0 Posted December 13, 2011 @ Dario: Daj reci onda koji tocno model gatewaya bi se trebalo kupit na ebayu za golfa 5 2006 godina da to funkcionira kak spada. Jer bi i ja htio kupit RNS 510. Thanx Share this post Link to post Share on other sites
Dario_7R 34 Posted December 13, 2011 bilo koji noviji od xxx530k na vise ,zadnji trenutni je 530aa Share this post Link to post Share on other sites
Lycan 0 Posted December 14, 2011 Muci me da uzmem ovaj model 7N0907530 HW 1K0907951 Date of manufacture: : 09 - 2010 ili ovaj ovdje 1K0 907 530 AD - Date of manufacture: : January 2010 Ako radi sa ova dva onda nebitno koji uzmem. Al kolko sam naso na netu ovaj 7Nxxxxx je kao zadnji Thanx Share this post Link to post Share on other sites
