MarioIV 11 Posted April 20, 2014 Pa pitaj tamo gdje bi kupovao. Ne mozes dobiti bolju informaciju nego od onog tko to prodaje. Share this post Link to post Share on other sites
master 2 Posted April 21, 2014 Jel se da isključiti code na rcd510 ili kako isprogramirati da auto ne traži code? Share this post Link to post Share on other sites
MarioIV 11 Posted April 21, 2014 lakse ti je zamjenit gateway nego to Share this post Link to post Share on other sites
Leic 2 Posted April 21, 2014 (edited) @ruby radio je original, i naravno da ce radit prikaz senzora @master koliko znam kod je u satu, mozda se i da ali treba neko sa odgovarajucom opremom i znanjem. Lakse doc do koda Edited April 21, 2014 by Leic Share this post Link to post Share on other sites
kreza 0 Posted April 21, 2014 Ili normalni rcd510 ili rcd510 za kinesko trziste Sve ostalo je s.... Share this post Link to post Share on other sites
MarioIV 11 Posted April 21, 2014 @ruby radio je original, i naravno da ce radit prikaz senzora @master koliko znam kod je u satu, mozda se i da ali treba neko sa odgovarajucom opremom i znanjem. Lakse doc do koda kod je getveju Share this post Link to post Share on other sites
master 2 Posted April 21, 2014 lakse ti je zamjenit gateway nego to Ma to ce i biti jedino rjesenje, jer prespojeno je da ne vuce struju na petici, al onda treba ukucati kod svaki put, jer ista plus zica ide na radio code i glavno napajanje. Mogu spojiti poseban stalni plus na code i ne bi ni trebalo gateway al eto ne zeli se rezati po instalaciji. Ima tko za prodati gateway na forumu ili sa ebaya jedino? Share this post Link to post Share on other sites
MarioIV 11 Posted April 21, 2014 imam ja getvej original nije iz kine . imas pm Share this post Link to post Share on other sites
Leic 2 Posted April 21, 2014 (edited) kod nije u gatewayu ja sam mjenjao gateway pa svejedno moram kucat kod Edited April 21, 2014 by Leic Share this post Link to post Share on other sites
master 2 Posted April 21, 2014 imam ja getvej original nije iz kine . imas pm Javim ti se, samo da nadj ko jos moze kodirati mi blizu kod nije u gatewayu ja sam mjenjao gateway pa svejedno moram kucat kod Kako mislis ako si ugradio gateway? Jel ti poslije tko iskodirao? Sta svaki put ili? Za to ni ne treba gateway, premostis osigurac u 5 minuta posla Share this post Link to post Share on other sites
MarioIV 11 Posted April 21, 2014 sad trazi kod jer nema stalnu struju kad se spoji kak treba i promjeni getvej nema problema Share this post Link to post Share on other sites
damarko 0 Posted May 26, 2014 Pozdrav ljudi. Pitanje, dali je ovo model koji se kupuje ? Hvala. http://www.njuskalo.hr/auto-mp3-cd-dvd/vw-rcd-510-bosch-rds-om-oglas-10655031 Share this post Link to post Share on other sites
MarioIV 11 Posted May 26, 2014 (edited) to je moj radio i sve je onako kako pise. Edited May 26, 2014 by MarioIV Share this post Link to post Share on other sites
ruscic 2 Posted May 31, 2014 kod je getveju kod je u radiu. dvi znamenke su u eepromu a druge dvi u procesoru. nije bas lako dekodirat ovi radio, osim ovlaštenog!!! a za maknit kod koliko znam nema rjesenja. Share this post Link to post Share on other sites
IVAN_VXR 0 Posted May 31, 2014 kod je u radiu. dvi znamenke su u eepromu a druge dvi u procesoru. nije bas lako dekodirat ovi radio, osim ovlaštenog!!! a za maknit kod koliko znam nema rjesenja. Postoji jedan interface kojeg prave Poljaci i njegova cijena je oko 2000 eura.Sa njim se može i nariktati kod koji tebi odgovara. Share this post Link to post Share on other sites
ruscic 2 Posted May 31, 2014 kod je u radiu. dvi znamenke su u eepromu a druge dvi u procesoru. nije bas lako dekodirat ovi radio, osim ovlaštenog!!! a za maknit kod koliko znam nema rjesenja. Postoji jedan interface kojeg prave Poljaci i njegova cijena je oko 2000 eura.Sa njim se može i nariktati kod koji tebi odgovara. AL NEMOŠ MAKNIT KOD DA GA NE TRAŽI KOLIKO ZNAN: ja iman za rns 510, mogu minjat kod i serijski broj za nekih cca 2 min. rcd san nekidan radia na programator i triba izgubit po ure uru ovisi.. a i radin u ovlaštenom..... broj sasije i serijski... i eto ga... Share this post Link to post Share on other sites
IVAN_VXR 0 Posted May 31, 2014 Znam da se kod ne moze maknuti totalno.. Radim i ja,cak smo ista firma samo sto samnja drugi dio :-) iako me ovaj vise zanima,al jbg sad Share this post Link to post Share on other sites
IVAN_VXR 0 Posted June 1, 2014 j... kolko nas ima! :bravo Share this post Link to post Share on other sites
Dottore 0 Posted August 11, 2014 Baš pitam, da li na njuškalu vrti replika RCD 510? Mislim ono, cca 1600 - 2200 kn? Share this post Link to post Share on other sites
DelPeric 0 Posted September 4, 2014 Pozdrav, jedno pitanje.. Sa svojim Polom sam dobio rcd 310. Jako mi se sviđa kako izgleda model rcd 510(ne znam razliku rns/rcd).Koliko sam shvatio on je multimedia(DVD, Navigacija, Bluetooth za razgovore s mobitelom i sl.) Da li je isplativo i koliko bi koštala promjena kod nas(u Splitu živim, ali nije daleko ni Zagreb). Ako je netko napravio sličnu stvar molim kratki savjet i informacije Hvala! Share this post Link to post Share on other sites
vlaho 2901 1 Posted September 4, 2014 RNS ima navigaciju i hard disk, RCD nema. Bluetooth modul mogu imat oba dva, a ne moraju, to je isto bila nadoplata. Isto je i za rikverc kameru kameru i OPS senzore. Moj RCD510 ima sve te opcije i prezadovoljan sam uredjajem. Kamera radi odlicno, i iznenadjujuce je dobra slika po noci. Za moje potrebe, 8 oem zvucnika je sasvim dovoljno i zadovoljan sam sa zvukom. Za ugradnju, a mozda i nabavku uredjaja i ako hoces jos nesto uz njega, ja mogu preporucit clana Lala30.. On je meni u golfa ubacivo RNS510 i GPS antenu na krovu. Posao odradjen po tvornickim standardima ?? Share this post Link to post Share on other sites
DelPeric 0 Posted September 4, 2014 Ok, to sve što si nabrojio me zanima, osim rikverc kamere koja mi recimo nije prioritet. Okvirna cijena uređaja tvog RCD510(sa ugradnjom?) je kolika otprilike? Thnx Share this post Link to post Share on other sites
Guest Laky Posted September 4, 2014 (edited) Rns 510 racunaj 6500 kuna s GPS antenom i ugradnjom.. Rcd se moze naci za 1500 kuna pa nadalje Edited September 4, 2014 by Laky Share this post Link to post Share on other sites
MarioIV 11 Posted September 4, 2014 Imam ja R verziju novo Share this post Link to post Share on other sites
