Royal mk7 0 Posted January 28, 2016 http://www.ebay.com/itm/Volkswagen-Plug-Play-CanBus-Adapter-VW-LED-1K8943021C-1K8943021-Golf-Polo-/200827419879?hash=item2ec23f3ce7nisam siguran jel se smiju stavljat linkovi.....evo carsystem.pl na ebayu.... Share this post Link to post Share on other sites
tihca 0 Posted January 28, 2016 Hvala dečki...Dino mi je dao meni jednostavnu varijantu,ako nejde onda budem direkt probao sa njihove stranice Share this post Link to post Share on other sites
Royal mk7 0 Posted January 28, 2016 Tihica ja sam kupovao preko ebay-a od njih i savršeno sve stigne kao i dogovoreno....jako zadovoljan... Share this post Link to post Share on other sites
Luka_DSG 1 Posted January 28, 2016 CarSystems je ok Uzeo sam od njih OPS centralu i jos toga i sve 5 Share this post Link to post Share on other sites
vlaho 2901 1 Posted January 28, 2016 Kod koga ste uzeli ledice? Narucio sam taj kabel gore. Bit će kući kroz par dana kazu.. Share this post Link to post Share on other sites
projektilski 277 Posted January 28, 2016 Ja nisam bas zadovoljan sa carsystems. Prekratki kablovi, losi senzori, krivi pinovi i nepostojeci pinvi na pdc gumbu (a kunu se da je sve ok) itd... Mozda sam imao peh ali nisu mi bas nesto. Share this post Link to post Share on other sites
Dario_7R 34 Posted January 28, 2016 3x BT kita 2x OPS kita 3x sitnice 4x razni adapteri 1xMDI i razne sitnice samo jednom je bio problem oko konektora BTa i to su rjesili unutar 4 dana ,poslali drugi jack Share this post Link to post Share on other sites
tomos222 1 Posted January 31, 2016 imam original OEM Led za tablicu,ali mi javlja grešku...nemože se kodirat jer je ispod MY2012....tražim onaj Canbus kabel na ebay-u pa molim preporuke i link ako netko zna koji da uzmem,znači e-bay neda mi se sdrugih stranica naručivat ili ako netko može to riješit nekak nek kaže... Ja narucio od carsystemsa takav kabel i javljo istu gresku ko i bez njega Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 17, 2016 Ja dobio te kablove neki dan i sad moram naći ledice da ih pokusam spojiti. Pa cemo vidit sto ce biti. Ako kome trebaju,mogu ih i prodati dalje ?? Share this post Link to post Share on other sites
tomos222 1 Posted February 17, 2016 Kak je to moguce? Neznam, ali kolega s foruma Pero cak moze potvrdit, a i moze potvrdit da se na mom neda kodirat ta greska,sa i bez kablova. Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 17, 2016 Ja sam dobio te kablove (adaptere) prije par dana, ali sad kad ovo citam, kontam, isplati li mi se uzimati i oem ledice, pa da opet imam gresku na tabli. Vidim da na Njuski ima neko ko prodaje kucista sa ledicama koje su kao error free. 250kn je cijena. Nisam pametan sto napraviti. Ne bacaju mi se pare na sve te djidje midje.. Share this post Link to post Share on other sites
master 2 Posted February 17, 2016 Te error free svjetle za ubit covjeka iza sebe. U onaj drugi topic sam stavio linkove, oem ledice(bar izgledaju kao oem, imaju kataloski i normalno svijetle) i otpornici 24 dolara. Plug&play sve Prvotno sam uzeo ledice i kodirao, bacalo gresku, kupio otpornike i sve radi bez greške Share this post Link to post Share on other sites
vlaho 2901 1 Posted February 17, 2016 U koji drugi topic? Share this post Link to post Share on other sites
master 2 Posted February 17, 2016 http://www.vwclubcroatia.com/forum/index.php?/topic/74046-Led-osvjetljenje-tablice---savjeti Share this post Link to post Share on other sites
