Bagi
P: muzike
Sutra stavim slike.
Radio Alpha (skoro nov)
Radio Gamma (rabljeni)+etui za pločicu
6 x CD-changer Audi (rabljen) sa pripadajućim kabelom
Radio VDO dayton CD 2302 sa daljinskim (rabljen)
evo slika:
VDO+daljinski- zapakiran........600 kn;
alpha.....................................150 kn;
gamma+etui za pločicu............450 kn;
CD-changer+kabel..................400 kn.
Edited by Bagi
CD-changer ...PRODAN
Edited by Bagi
4x55 Watts
4-Channel 4V Preamp Out
The 4-channel line out multiplies the sound power combinations and
pre-amplifier connections. In order to optimize at its maximum the signal
to noise ratio and increase the dynamic, outputs are supplied at 4V.
Bass Boost System (BBS)
Boosts the bass out of the set!! This function is selected via a direct key
access. 3 levels of effect can be chosen according to your preference.
Handsfree Phone In
With the Handsfree Phone In function you have a Plug & Play solution, to
connect the VDO Dayton Handsfree Phone Kit. Using the high sound quality
of your In-Car HiFi, phone sound is processed through your loudspeakers,
enabling a relaxed telephone call. The VDO Dayton Handsfree Phone
Kit includes a microphone and is available for the most popular mobile
phones on the market. In addition, the car radio provides the power supply
to keep the battery of your mobile fully charged.
Speed Dependent Volume Control (SDVC)
When connected to the speedometer signal of the car, the volume ist automatically
adjusted to always get the best of the sound.
Software Access Menu (SAM)
"Software Access Menu" is an easy way to personalise your VDO Dayton
car radio according to your choice and install all possible options. You can
adjust the level of the Traffic Announcement volume, as well as other
sound effects. Navigation and Handsfree mute signal level is selectable to
suit your equipment. You are able to choose which SDVC curve is most efficient
for your car, adjust the Clock settings plus many other options.
Ovo sam jo?? na??ao, ni??ta nije kori??teno, mislim da bih ne??to mogao prodati.
1700,00kn
po dog. (narud??ba)
po dog. (narud??ba)
Sve su HU sa DVD. Prva dva sa zaslonom od 3.6", a zadnji 7"je na izvlačenje,
Nisu nikakav Brand name, ali ćete primjetiti "slučajnu" sličnost s JVC ili drugim uređajima.
Edited by Bagi
MEENNNIIIIIIII. Stuniral sam starome Passata.
kolko ovaj zadnji za izvlacenje????ima izlaz za zvucnike ili je to samo player??
ovaj ide u Golfa, čekam jo?? stropni monitor Alpine PKG 850, ide i shark antena gore pa mi se ne da dvaput raskopavat auto. Ne znam točnu cijenu, ali bi se trebala kretati 3000-3300 kuna.
Imam samo po jedan primjerak.
ja imam ovakav slican vdo hu samo kaj moj ima mp3 i fakat je best buy za te pare,super izgleda uzivo!ima neke funkcije koje jos nisam vidio na kazicu...napredno trazenje pjesama i jos gluposti raznih...
svakako preporucujem! :palacg
jbg, kad sam kupovao nisam ??elio MP3, jer slabo ??ta slu??am u komprimiranim formatima, a ??ta će?? nisam razmi??ljao o prodaji.
uglavnom na uređaj se mogu spojiti parking senzori, handsfree preko zvučnika, pojačala, itd. ja sam ga platio oko 23kkuna
jel imas mozda za njega original onaj kao konektor sto dodje gdje su preout izlazi jer ja sam za pojacalo stavio male stopice iza na one izvode jer moj nema chincheve iza ak si me shvatio sta sam napisao jer ni ja sebe nisam shvatio..... :)
e da sto se ovih no brand dvd-ova tice:jel samo cash dolazi u obzir ili su moguce i kombinacije kakve?
Edited by HUZO
imam konektor za pojačalo, ali ide uz radio, sorry
samo cash, kombi isklj.
DVD-a vi??e nema (trenutno) iđemo dalje: Alpha, Gamma, VDO Dayton.
Edited by Bagi
Stiglo i ne??to novo:
1. Entertainment center integriran u ko??om presvučen naslon za glavu.
Sadr??i DVD player, koji podr??ava DVD/VCD/CD, itd...u raznim formatima DIVX/JPEG/MPEG/WMA itd.
Tu je utor za memorijsku karticu, a i USB priključak.
Također sadr??i VCD sa igrama, te naravno dva game-pad-a; IR daljinski upravljač, podr??ava IR slu??alice
koje nisu isporučene, te sve ??to je potrebno za monta??u. Display je 7" LCD wide.
1850 kuna.
2. 1-DIN DVD player/tuner/TV 4x60W sa 4" TFT motoriziranim monitorom,ANTI-SHOCK, PAL/NTSC kompatibilan, kut/memorija pozicije, AM/FM/MPX stereo reciever sa 30 postaja, TV tuner sa 100 postaja, Auto store memorije, EQ sa 3 predpostavljene postavke POP/ROCK/CLASSIC, parking dist. interface, 2 RCA izlaza za PREAMP, izlaz za SUB, izlaz za dodatni monitor, AUX, USB i CARD reader, daljinski, BLUETOOTH za mobilni telefon...
2200 kuna
Edited by Bagi
EDIT:
Danas ugrađen u Hyundai Tucson
Edited by Bagi
E to mo??e?? kupiti u svakom BOSCH servisu gdije imaju i BLAUPUNKT, pa??e oriđiđi i ko??ta oko 80kn, mali konekror s jedne strane i četiri činča s druge plus ??ica s plus prekidanim izlazom za paljenje pojačala!
naslonjači rasprodani, ostalo jo?? u ponudi
*************EDIT*****************
prodan GAMMA
Edited by Bagi
BUMP!
Stigli su ponovno nasloni za glavu s integriranim DVD+monitorom.
eh, kasno pali??, sad svira u lupaću, jer je osto bez DVD-a
A oće bit na prodaju?
