zvonexp 10 Posted March 11, 2017 Bio sam ja neki dan kod njih pa sam pitao, nemogu se montirati. trebalo bi mjenjat neke module, procesor itd.. kao da je neisplativo to radit.. sada su od normalnog 7 R sa montažom 4050kn Share this post Link to post Share on other sites
zvonexp 10 Posted April 4, 2017 Koga u ZG sve pitat za stavit LED farove iza ? Share this post Link to post Share on other sites
MarioIV 11 Posted April 4, 2017 Plug play samo kodirat Imas na youtube Share this post Link to post Share on other sites
Rolic142 1 Posted April 4, 2017 Koga ima u Zagrebu ko ih prodaje i ugrađuje? Share this post Link to post Share on other sites
marioGt 2 Posted April 4, 2017 Treba i žice vući na vrata Poslano sa mog HUAWEI VNS-L21 koristeći Tapatalk Share this post Link to post Share on other sites
zvonexp 10 Posted April 4, 2017 Da to je i meni rečeno da nije baš plug and play.. ako su oem Share this post Link to post Share on other sites
K0k0Pu 1 Posted April 5, 2017 već sam vam pisa al evo opet, ja sam original od R-a ugrađiva u Eurodausa (znači prije mene su in ljudi nosili ta plug and play sranja) i momci su mi to spajali 6 sati jer ima tu dosta zajebancije. Share this post Link to post Share on other sites
MarioIV 11 Posted April 5, 2017 Mislio sam na ove sa dynamic zmigavcima Share this post Link to post Share on other sites
Roby ZD 6 Posted May 13, 2017 Mislio sam na ove sa dynamic zmigavcima Bilo ih je u ponudi u zadnjem cini mi se VW letku. 3728 kn je bila cijena Share this post Link to post Share on other sites
Roby ZD 6 Posted July 9, 2017 Zna li netko koga u ZD gdje bi se moglo ugraditi LED straznja svjetla, da ne idem u VW. Iskodirao bih sam kad VCDS stigne za koji dan Share this post Link to post Share on other sites
zvonexp 10 Posted July 9, 2017 Sam ih ugradi, plug and play su.. ako su original Share this post Link to post Share on other sites
Roby ZD 6 Posted July 9, 2017 Uzeo bi origigi, ali ima posla oko provlacenja kebela s vanjske jedinice u unutrasnju (dio na prtljazniku) Gledao sam par filmica na jubitu Share this post Link to post Share on other sites
marioGt 2 Posted July 9, 2017 Oem nisu p&p...treba žicu provući za zmigavac na vratima Al pitaj kod ovlaštenoga...u zgb. ne uzmu puno... Share this post Link to post Share on other sites
Roby ZD 6 Posted July 9, 2017 (edited) Oem nisu p&p...treba žicu provući za zmigavac na vratima Al pitaj kod ovlaštenoga...u zgb. ne uzmu puno... ZGB mi je taman iza kantuna. Cekam da malo sunce padne Edited July 9, 2017 by Roby ZD Share this post Link to post Share on other sites
Roby ZD 6 Posted July 14, 2017 Pitao kod ovlaštenog...kao da su s Marsa pali..(Ili sam možda ja).. "Nemamo mi to i ne može se ugraditi"...kaže prodavač. A lijepo ih reklamiraju u onom svom letku koji dolazi svakih par mjeseci. Sad čačkam po netu di bi ih nabavio, jer cijene (kažu OEM) variraju od 400 do cca 600 Eur. Meni bi odgovarala varijanta Cherry Red. One tamne poput R-a mi ne pašu na boju Limestone Grey metallic Share this post Link to post Share on other sites
zvonexp 10 Posted July 15, 2017 Oem nisu p&p...treba žicu provući za zmigavac na vratima Al pitaj kod ovlaštenoga...u zgb. ne uzmu puno... Pitaj Belog.. meni je ugrađivao i sve pregledao sve radi Share this post Link to post Share on other sites
marioGt 2 Posted July 15, 2017 Da...ali na vrata treba vuci instalaciju za zmigavac... Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
zvonexp 10 Posted July 15, 2017 Bio sam kod čovjeka, znači prvo u VCDS stavio umjesto bulb led i zamijenio sva 4 fara iza i testirao sve i radilo nikakve kemije sa žicama itd.. ili auti iznad 2015 imaju to već sve u sebi Share this post Link to post Share on other sites
marioGt 2 Posted July 17, 2017 (edited) Nema nikakve kemije kada na led faru zmigavac ima i na gepeku a na običnima samo na vanjskoj lampi pa ne znam kako bi radilo...ali totalno nebitno... Edited July 17, 2017 by marioGt Share this post Link to post Share on other sites
vento 0 Posted November 9, 2017 (edited) Led straznja svjetla (R-line) https://shop.ahw-shop.de/led-rueckleuchten-set-original-vw-golf-7-tuning-leuchten-5g1052200-heckleuchten?c=7185 Stigla i postavljena Edited November 24, 2017 by vento Share this post Link to post Share on other sites
Speed 0 Posted December 2, 2017 Lijepo izgledaju. Te su pretpostavljam na FL modelu dolazile standardno? Share this post Link to post Share on other sites
Roby ZD 6 Posted December 3, 2017 FL ima full drugacija svjetla. Uz nadoplatu su LED s dinamičkim žmigavcima Share this post Link to post Share on other sites
Speed 0 Posted December 3, 2017 To bi onda bila ova svjetla? Share this post Link to post Share on other sites
Antonio143 0 Posted December 4, 2017 (edited) To bi onda bila ova svjetla? To su standardna svjetla koja dolaze na G7.5, a uz nadoplatu dolaze sa dinamičkim žmigavcima, tj. u auto kući ponude da biraš besplatnu opciju Zimski paket ili ta svjetla sa dinamičkim žmigavcem, nedavno sam naručivao G7.5, pa evo znam konkretno šta su mi nudili. Edited December 4, 2017 by Antonio143 Share this post Link to post Share on other sites
