Leo-st 5 Posted January 16, 2018 (edited) Super je ispalo,znači jedna je ipak bila naopako ajde neka si rjesio Edited January 16, 2018 by Leo-st Share this post Link to post Share on other sites
<TDI> 509 Posted January 16, 2018 Kad se zauzme za nesto onda ne pusta dok to ne rijesi haha. Share this post Link to post Share on other sites
markol5 15 Posted January 16, 2018 Super je ispalo,znači jedna je ipak bila naopako ajde neka si rjesio Je ona prva livo,jesam one dvi 20puta odlemio i zalemio imas pivu Kad se zauzme za nesto onda ne pusta dok to ne rijesi haha.Bas tako Share this post Link to post Share on other sites
jooka 1 Posted January 16, 2018 Evo gotovo,jednu ledicu nisam stavio kako treba i suprotne dvi nisu radile jer su u peraleli,zadovoljan rezultatom! U nastavku slika kako se poredaju ako ce netko slagat na VDO sat markol5 svaka čast. Mirna ruka i velika volja Share this post Link to post Share on other sites
Leo-st 5 Posted January 25, 2018 (edited) Mali update,naručena samoljepljiva folija sa aliexpresa i promjenjena na dva mala lcd i na climatronicu sada to ovako izgleda slikano malo boljim mob.... link za foliju:https://www.aliexpress.com/item/20-30MM-Linear-Polarizer-Film-Linear-Polarized-Filter-3D-Linear-Polarized-Film-0-19mm-Polarizer-filter/32804985320.html?spm=2114.13010708.0.0.Azj2hLPoslano sa mog MI 5 koristeći Tapatalk Edited January 25, 2018 by Leo-st Share this post Link to post Share on other sites
bozic.hrvoje 0 Posted January 25, 2018 Mali update,naručena samoljepljiva folija sa aliexpresa i promjenjena na dva mala lcd i na climatronicu sada to ovako izgleda slikano malo boljim mob.... link za foliju:https://www.aliexpress.com/item/20-30MM-Linear-Polarizer-Film-Linear-Polarized-Filter-3D-Linear-Polarized-Film-0-19mm-Polarizer-filter/32804985320.html?spm=2114.13010708.0.0.Azj2hL Poslano sa mog MI 5 koristeći Tapatalk Da li je ispalo blizu onom audi style-u ( crna pozadina crvena slova ) ? Sent from my Redmi Note 4 using Tapatalk Share this post Link to post Share on other sites
Leo-st 5 Posted January 26, 2018 Da li je ispalo blizu onom audi style-u ( crna pozadina crvena slova ) ? Sent from my Redmi Note 4 using Tapatalk Je jako je slično Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
bozic.hrvoje 0 Posted January 26, 2018 Je jako je slično Poslano sa mog MI 5 koristeći Tapatalk Ako nije problem, poslikaj po noci instr tablu lad radi, ali bez blica Sent from my Redmi Note 4 using Tapatalk Share this post Link to post Share on other sites
Leo-st 5 Posted January 26, 2018 Četvrta slika je bez blica Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
<TDI> 509 Posted January 26, 2018 Prelijepo. Ne vidi se uopće razlika kada se pogleda i usporeddi OEM fis i LCD od datuma i kilometara, također i na climatronicu je sad sve ujednačeno, perfa. Share this post Link to post Share on other sites
Leo-st 5 Posted January 26, 2018 Da ovo je sad ok jer je folija lijepo zaljepljena na lcd,jedino sto je razlika folija je sjajna a na fis lcd je matirana Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
<TDI> 509 Posted January 26, 2018 Da li si pokušao tražiti matiranu foliju? Share this post Link to post Share on other sites
Leo-st 5 Posted January 26, 2018 A nisam i ovo sam jedva našao ima ih puno vrsta Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
<TDI> 509 Posted January 26, 2018 Bas, gledao sam i ja ali nigdje ne pise mat ili glossy ali bilo bi dobro jos i taj detalj imati da se uklopi u cjelinu. Inace ne volim taj sjajni efekt kod LCDa pa bih svakako potrazio mat foliju. No, svaka cast na volji i trudu jer malo tko bi toliko puta vadio i sve to ponovno radio. Steta da folija nije mat jer bi onda bilo savrseno ali na taj detalj se ni ja nisam sjetio iako su u originalu svi LCDi mat. Share this post Link to post Share on other sites
Leo-st 5 Posted January 26, 2018 Ako ćeš iskreno to se jedino preko dana malo primjeti, po noći je ista stvar... Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
ivan25 17 Posted February 18, 2018 pozz! mjenjao bi sat u svom gofu 4 1.8t (auq)2003g. imam ovaj s crnom podlogom s mfa display,stavljao bi ovaj s sivom podlogom isto je s 1.8t motora ima isto mfa display. dali se mora sta kodirati ili se samo usteka. hvala! Poslano sa mog PRA-LX1 koristeći Tapatalk Share this post Link to post Share on other sites
mur3633 241 Posted February 18, 2018 Potrebno ga je ukodirati. Sent from my Redmi Note 3 using Tapatalk Share this post Link to post Share on other sites
Leo-st 5 Posted February 18, 2018 Kodiranje sata i uparivanje ključeva moraš napraviti... Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
ivan25 17 Posted February 18, 2018 ok! hvala to se sve preko vcds-a odradi jel? Poslano sa mog PRA-LX1 koristeći Tapatalk Share this post Link to post Share on other sites
Leo-st 5 Posted February 18, 2018 Da ako već imaš sck kod ako nemaš onda ti treba vagtacho za taj kod i vcds za uparivanje i da sa vagtacho korigiraš km da budu isti i na novom satu Poslano sa mog MI 5 koristeći Tapatalk Share this post Link to post Share on other sites
<TDI> 509 Posted February 18, 2018 Imas tu malo pojasnjeno ... Popravak kljuca_( http://www.vwclubcroatia.com/forum/index.php?/topic/90287-popravak-kljuca/page-2) Share this post Link to post Share on other sites
ivan25 17 Posted February 18, 2018 jel mozes malo pojasnit ako nije problem te kodove ? mene samo zanima hocu moci to zamjenit ,sat skidam s Bore hvala! Poslano sa mog PRA-LX1 koristeći Tapatalk Share this post Link to post Share on other sites
luka93 20 Posted February 18, 2018 Ako imaš vagtacho i vcds moć ćeš sam odradit. Ako nemaš, plati nekome 400-500-600kn i eto Share this post Link to post Share on other sites
markol5 15 Posted February 18, 2018 Moze li se na g5 ikako smanjit intezitet svjetala unutrasnjosti,prvenstveno za sat? Samo pinku Share this post Link to post Share on other sites
<TDI> 509 Posted February 19, 2018 S koliko mcda su bile tvoje bijele ledice? Share this post Link to post Share on other sites
