Jovan97 1 Posted July 23, 2022 (edited) Pozdrav ekipo, kupio sam pre 3dana devojci malo stariju a3(2005) ali imam neke probleme, mozda se neko susreo ili zna nesto pa ne bi bila lose mala pomoc. ovo je skenirano odma nakon kuppvine: VCDS SKEN Od toga sam resio vecinom(ali sam zaboravio da sacuvam sadansnje skeniranje) ostalo je jedino Address 15: Airbags Labels: 8P0-959-655-94.lbl Part No SW: 8P0 959 655 C HW: 8P0 959 655 C Component: Airbag 9.41 H10 3230 Revision: 91H10323 Serial number: 003620044F5$ Coding: 0073622 Shop #: WSC 06314 000 00000 VCID: 42925B33848F241249F40CD-8016 2 Faults Found: 00590 - Igniter 2 for Passenger Airbag (N132) 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 188 Mileage: 229188 km Time Indication: 0 Date: 2021.03.08 Time: 00:01:29 01044 - Control Module Incorrectly Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 188 Mileage: 229188 km Time Indication: 0 Date: 2021.03.08 Time: 00:01:29 Address 46: Central Conv. Labels: 8P0-959-433.lbl Part No: 8P0 959 433 E Component: KSG H04 0050 Coding: 188000186D088505488F016000 Shop #: WSC 06314 000 00000 VCID: 3E6A2FC3F07740F22D0C78D-806A Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 01565 - Luggage Compartment Light (W3) 007 - Short to Ground I da, klima kao da ne zeli da se ukljuci, obrisao sam greske prikao senzor koji nije bio nakacen ali i dalje nesto ne zeli(ima li neki nacin da se testira kompresor?) I posto imam Pasata B6 skoro identicnom ovome, nisam primetio nikakvu RUPU pored anlasera/menjaca, dok ovde ima?? Vidim lagano zupcenike, tako treba ili? Hvala puno *ps zaboravi da napomenem da je audi bio vozen od strane neke dece, koja su pokusaa da promene tablu i napravili haos(zbog immo) pola kablova nije bilo povezano, esp je stajao(jedva sam uspeo odraditi “basic settings” za g85,g200 i brake presure) Edited July 23, 2022 by Jovan97 Share this post Link to post Share on other sites
ALE009 20 Posted July 24, 2022 dzek od airbaga suvozacevo sjediste i nesto nije fino iskodirano Share this post Link to post Share on other sites
Jovan97 1 Posted July 24, 2022 17 minutes ago, ALE009 said: dzek od airbaga suvozacevo sjediste i nesto nije fino iskodirano Dzek cu proveriti ali kodiranje… moracu da nadjem nekog slicnog da prekopiram kod za modul airbega Share this post Link to post Share on other sites
<TDI> 509 Posted July 24, 2022 Na kućištu od mjenjača ti fali poklopac koji tu ide, zato se vide zupčanici od zamašnjaka. Potraži na otpadu takav, mislim da su svi manje više jednaki ili napravi upit u ovlaštenom ili nekoj trgovini... 1 1 Share this post Link to post Share on other sites
derba 3 Posted July 24, 2022 Neki dan sam i ja vidio da nemam taj cep zamajca na mom b6 ,ali sam radio nesto drugo pa sam to zanemario. Logicno mi sad da tu ide cep . Share this post Link to post Share on other sites
Jovan97 1 Posted July 24, 2022 40 minutes ago, <TDI> said: Na kućištu od mjenjača ti fali poklopac koji tu ide, zato se vide zupčanici od zamašnjaka. Potraži na otpadu takav, mislim da su svi manje više jednaki ili napravi upit u ovlaštenom ili nekoj trgovini... E to me zanimalo, potrazicu na otpadu, bilo mi cudno da je tako, upadne nesto izmedju polomice sve :D Ja kod mene na b6 cini mi se da je tu sve metalno nema ni otvora ni cep :D al nije bitno vazno... Hvala Share this post Link to post Share on other sites
<TDI> 509 Posted July 24, 2022 Ma ništa, bilo bi dobro staviti taj čep da si miran i da nešto ne upadne u zamašnjak, pogotovo kada se radi oko motora. Sretno sa ostalim kvarovima, nadam se da ćeš ih riješiti. 1 1 Share this post Link to post Share on other sites
